Hi Guys!
Found this little beauty a few days ago, and it is proving really useful (author unknown, sorry).
However, I have a few problems with it and I'm asking for help!
i. I cannot get it to run from the command prompt using "trim2lay", but have to load it each time I want to use it. How do I overcome this?
ii. What code is needed to allow an entity selection for the desired destination layer?
Hope someone can help.
Many thanks,
KIEREN
Code:; This macro performs a "TRIM" om selected entities ; an transfers the "EXCESS" section of the entity onto ; a user defined layer. This can be used with a layer ; with a "hidden" linetype to illustrate a section of a ; part obscured from view. ; If an entity is selected that does not intersect ; a boundary, it is "CHANGED" to the transfer layer. ; The macro will only work with LINES,ARCS and CIRCLES. ; All other entities will be ignored. ; Enter a null reponse to the entity selection prompt ; to terminate the command. ; Function to store system variables (defun MODES (a) (setq MLST '()) (repeat (length a) (setq MLST (append MLST (list (list (car a) (getvar (car a)))))) (setq a (cdr a))) ) ; Function to reset system variables (defun MODER () (repeat (length MLST) (setvar (caar MLST) (cadar MLST)) (setq MLST (cdr MLST)) ) ) ; Function to conceal arcs (defun XARC (/ cen r) (command "LAYER" "S" $ln "") (setq a (cdr (assoc 50 e1))) (setq b (cdr (assoc 51 e1))) (setq cen (cdr (assoc 10 e1))) (setq r (cdr (assoc 40 e1))) (command "TRIM" ss "" (cadr e) "") (setq e2 (entget (car e))) (setq c (cdr (assoc 50 e2))) (setq d (cdr (assoc 51 e2))) (cond ((equal e1 e2) (command "CHANGE" (cdar e1) "" "P" "LA" $ln "") ) ((and (equal a c) (/= b d) (equal el (entlast))) (command "ARC" (polar cen d r) "c" cen (polar cen b r) ) ) ((and (equal b d) (/= a c) (equal el (entlast))) (command "ARC" (polar cen a r) "c" cen (polar cen c r) ) ) (T (setq x (cdr (assoc 50 (entget (entlast))))) (setq y (cdr (assoc 51 (entget (entlast))))) (cond ((and (equal a c) (equal b y)) (command "ARC" (polar cen d r) "c" cen (polar cen x r) ) ) ) ) ) (command "LAYER" "S" cl "") ) ; Function to conceal circles (defun XCIRCLE (/ cen r) (command "LAYER" "S" $ln "") (setq el (entlast)) (setq cen (cdr (assoc 10 e1))) (setq r (cdr (assoc 40 e1))) (command "TRIM" ss "" (cadr e) "") (setq e2 (entget (car e))) (cond ((equal e1 e2) (command "CHANGE" (cdar e1) "" "P" "LA" $ln "") ) ((= (cdr (assoc 0 e2)) "ARC") (setq r (cdr (assoc 40 e2))) (setq cen (cdr (assoc 10 e2))) (setq a (polar cen (cdr (assoc 50 e2)) r)) (setq b (polar cen (cdr (assoc 51 e2)) r)) (command "ARC" b "C" cen A) ) ) (command "LAYER" "S" cl "") ) ; Function to conceal lines (defun XLINE () (command "LAYER" "S" $ln "") (setq a (cdr (assoc 10 e1))) (setq b (cdr (assoc 11 e1))) (command "TRIM" ss "" (cadr e) "") (setq e2 (entget (car e))) (setq c (cdr (assoc 10 e2))) (setq d (cdr (assoc 11 e2))) (cond ((equal e1 e2) (command "CHANGE" (cdar e1) "" "P" "LA" $ln "") ) ((and (equal a c) (/= b d) (equal el (entlast))) (command "LINE" d b "") ) ((and (equal b d) (/= a c) (equal el (entlast))) (command "LINE" a c "") ) (T (setq x (cdr (assoc 10 (entget (entlast))))) (setq y (cdr (assoc 11 (entget (entlast))))) (cond ((and (equal a c) (equal b y)) (command "LINE" d x "") ) ) ) ) (command "LAYER" "S" cl "") ) (defun c:trim2lay (/ cen r e el e1 e2 a b c cl d ln ss yn x y) (modes '("CMDECHO" "BLIPMODE" "HIGHLIGHT")) (setvar "CMDECHO" 0) (setvar "BLIPMODE" 0) (setq cl (getvar "CLAYER")) ;;prompt for layer (if (setq e (car (entsel "\nPick Destination Layer, or <return> to Type It: "))) (setq ilayer (cdr (assoc 8 (entget e)))) ) (if (not ilayer) (progn (setq ilayer (getstring "\nLayer: <Return> to Use Current Layer: ")) (if (not (tblsearch "LAYER" ln)) (progn (initget "Yes No") (setq prmpt (strcat "\nLayer " (strcase ln t) " does not exist. Create? <N>: " ) ) (setq yn (getkword prmpt)) (if (= yn "Yes") (command "LAYER" "n" ln "") (setq ln nil) ) ) ) ) ) ) (if (= ilayer "") (setq ilayer (getvar "CLAYER"))) (princ (strcat "\nOffsetting to layer " ilayer ".")) (prompt "\nSelect trim boundaries: ") (setq ss (ssget)) (setvar "HIGHLIGHT" 0) (setq e (entsel "\nSelect entity to transfer ")) (while e (setq e1 (entget (car e))) (setq el (entlast)) (cond ((= (cdr (assoc 0 e1)) "LINE") (xline) ) ((= (cdr (assoc 0 e1)) "ARC") (xarc) ) ((= (cdr (assoc 0 e1)) "CIRCLE") (xcircle) ) (T (prompt "\nUnsuitable entity selected. ")) ) (setq e (entsel "\nSelect entity to transfer ")) ) (moder) (princ) )
