Results 1 to 1 of 1
Thread: Setting the Scale units of a DWF file
    2005-08
    Northern Colorado
    100
    Question Setting the Scale units of a DWF file
    We're trying to figure out how to show the dimensions we want (basically to scale) from our DWG files.
    Currently, our DWG files are drawn in model space at full scale feet. Our DWF is created from a layout tab which is set to a plot scale of 1:8. Within that layout tab is a viewport which has a scale of anywhere from 1:7.62 to 12:500.
    Once the DWF file is created from this layout tab, and we try to measure anything within Design Review, it will only ever show model scale dimensions. We basically would like to shut off the associative dimensioning, and have it dimension at paper scale.
    How can we change the value of the DWF scale (bottom of attached dialog box) for a file?
  1. 2014: Setting Drawing Units for Survey
    By Iceberg in forum AutoCAD Civil 3D - Survey
    Last Post: 2013-12-16, 11:37 AM
  2. Roundoff setting in UNITS
    Last Post: 2012-07-16, 03:14 AM
  3. Setting the View scale in the Template file
    By Revit for Breakfast in forum Revit - Platform
    Last Post: 2009-04-16, 12:47 PM
  4. Invalid argument scale in setting standard scale property
    By gtepe.123006 in forum AutoCAD General
    Last Post: 2008-12-23, 02:10 AM
  5. Setting insertion units at open
    By cblendermann.91943 in forum AutoCAD Customization
    Last Post: 2005-08-31, 01:00 PM
