Thread: Purge textstyles in blocks
    2003-09
    3
    Default Purge textstyles in blocks
    Hi All;
    I have some files that contains dynamic blocks which are used
    in the ToolPalette.
    I tried to clean these files as much as possible but some textstyles still remained.
    I noticed that these textstyles were within the blocks, although not used.
    I opened a new drawing and purged it as much as possible and
    the I copied a block to this purged file and all the textstyles were back.
    I tried to use purge command in the blockeditor for the same block but that diddnt work
    either.
    Are there anyway to delete these textstyles.
    TIA
    David
    2005-07
    2,356
    Default Re: Purge textstyles in blocks
    Quote Originally Posted by david.hellberg View Post
    Hi All;
    in the ToolPalette.
    either.
    TIA
    David
    Can you post an example dwg file containing the rogue text styles.
    2005-06
    Brisbane-Australia & Phoenix Arizona
    80
    If the test style exists within the block, in the block editor assign the text to the
    style you want, or delete the text. Save and close block editor, then purge the drawing file.
    Leo
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    If there are attributtes in the dyn block, good luck. those can be particularly difficult to clean up. make sure you go into the block editor and change any attributtes in all visibility states to the desired style and make sure outside the block editor you set the the text for the attributes on properties to use the desired style and use battman to set the desired text style for all attributes.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2008-06
    39
    Post Re: Purge textstyles in blocks
    I have come across the same problem. Attached is a drawing that I'm trying to get the ATTR text style out but have had no luck. Any clue on how to get it out?
  1. Can not purge blocks from table
    By costas.vassiliou in forum AutoCAD Tables
    Last Post: 2011-06-13, 10:48 PM
  2. Purge Blocks Only
    By wpeacock in forum VBA/COM Interop
    Last Post: 2007-03-17, 04:08 PM
  3. How to purge these naughty blocks?
    By pravin_kulkarni in forum MDT - General
    Last Post: 2005-09-26, 08:03 AM
  4. how to purge deleted blocks
    By tim.ashton in forum VBA/COM Interop
    Last Post: 2004-10-29, 03:56 PM
  5. purge all not purging *__ (blocks)
    By michael.byrne in forum CAD Management - General
    Last Post: 2004-06-10, 06:06 PM
