Thread: Missing menu pulldowns
    2003-12
    Pittsburgh, PA
    355
    Default Missing menu pulldowns
    I've searched but can't find a fix...
    I am using C3D, with the main CUI 'CIVIL'. Also loaded are partial CUIs including 'ACAD', 'EXPRESS' a custom 'MY2008'. My problem is that not all of the menu pulldowns appear on the menu bar, although they're shown as loaded in the CUI (see attached). I can fix it by unchecking and checking the menu box in the left panel and then applying, but it gets to be a PITA to do each time I open Acad. Does anybody know what causes this and how to fix it?
    Thanks-
    2000-01
    Seattle WA USA
    5,859
    Default Re: Missing menu pulldowns
    You run into an artifical limit on the number of active menus on the menu bar. The active menus also happen to be stored in the registry, and there are only 24 "slots" available in the registry.
    So you either need to reduce the number of active menus to 24 or less, or load your workspace every time you start AutoCAD.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2003-12
    Pittsburgh, PA
    355
    That explains it. Thank you Robert.
  1. Maximum Menu Pulldowns?
    By lpseifert in forum AutoCAD CUI Menus
    Last Post: 2009-02-20, 12:18 AM
  2. Menu Pulldowns
    By sharla in forum ACA General
    Last Post: 2008-04-24, 10:44 PM
  3. Pulldowns from CUI menu disappear
    By rroberts in forum AutoCAD CUI Menus
    Last Post: 2008-04-22, 11:44 PM
  4. Pulldowns in my menu no show
    By louis.64641 in forum AutoCAD CUI Menus
    Last Post: 2006-12-28, 03:16 AM
