Results 1 to 10 of 13
Thread: Out of Memory error in LDT
    Member aforsman's Avatar
    7
    Question Out of Memory error in LDT
    I am not even sure if I am posting in the right place, but every time I open a project in Land Development, I get "Error opening point group database: Out of memory", "Error opening point XDRef database: Out of memory", "Error opening point DescKey database: Out of memory", & "Error opening point database: Out of memory". Can anyone tell me what is going on here? I already increased my virtual memory, I have no other programs running, I have 1GB of Ram, and 53GB of free space. Is it an r14 & XP compatibility issue? Thanks.
    2001-03
    13,499
    Default Re: Out of Memory error in LDT
    Hi
    Please note I've *moved* this thread from the CAD Mgmt. General Forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    2001-10
    Arizona
    2,337
    Quote Originally Posted by aforsman
    I think I have seen this before, and the solution has something to do with setting
    windows memory in the system.ini file
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    7
    Angry Re: Out of Memory error in LDT
    I have increased the memory, but still- I get the error message. :/
    2001-10
    Arizona
    2,337
    This is not about having enough memory.
    It is about having TOO much memory for
    R14 to address, thus you must reduce this value for
    R14 to work in the system.ini file.
    Be your Best,
    Michael Farrell
    7
    Oh, boy... this is a little over my head. Thanks for your help. I am just frustrated- I work for a town, so it is impossible to get involved in anything without being interrupted 20 times!
    7
    OK- That did not work. Any other suggestions at all? I also did a Windows reapir, then Uninstalled AutoCAD & LDT & Reinstalled them. I do not know what else to do.
    Civil Engineering Moderator MHultgren's Avatar
    Clyde, NC - USA
    1,381
    Exclamation Re: Out of Memory error in LDT
    Have you tried going to the desktop icon, right-click and select compatibility. then change it to run as if it were running on Windows NT. Make sure to check the box Make this change permanent or it will revert back to XP mode the next time you run it.
    Mark Hultgren
    Just a Lurker
    http://www.MKW-Ind.com
    Blog
    Socializing??
    7
    I tried to change the compatibility to Windows 95, NT, and 2000, but none of them fixed the problem. I am TOTALLY stumped.
    Clyde, NC - USA
    1,381
    Just a thought, do you have all the Service Packs installed? I think I might still have some of them for LDT1 somewhere.
    Mark Hultgren
    Just a Lurker
    Blog
    Socializing??
  1. Memory Error
    By RevitNinja in forum Autodesk Green Building Studio
    Last Post: 2009-10-27, 02:14 AM
  2. Fatal error: out of memory?
    By otto2_ in forum AutoCAD LT - General
    Last Post: 2009-10-06, 03:50 PM
  3. Memory Allocation error
    By ghero in forum ACA General
    Last Post: 2008-02-19, 11:12 PM
  4. Fatal Error: Out of memory
    By evan.haun in forum Land Desktop - General
    Last Post: 2006-10-28, 09:33 PM
  5. Memory Error while Plotting DWG to PDF
    By rhayes.99001 in forum AutoCAD Plotting
    Last Post: 2005-12-22, 04:11 PM
