Results 1 to 8 of 8
Thread: block stretching and the arrow that does the stretching
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,124
    Default block stretching and the arrow that does the stretching
    i have a noob-tastic question that i should know the answer to and cant figure out. i have a masonry section block that array's in one direction - the arrow for it should stay attatched to the top of the masonry, but for some reason it seems to make its home one full block height past the top, and it annoys me. what am i doing wrong with the block that makes it do this and how do i fix it? its been a while since ive toyed with more than a really basic DB and i dont remember some simple stuff like this
    danke.
    ps. i miss this forum
    edit: file upload
    This aggression will not stand. Man.
    Dynamic Blockhead Mod Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: block stretching and the arrow that does the stretching
    Quote Originally Posted by .chad View Post
    danke.
    is your parameter set to snap with the coursing?
    S&D DB Sharing Forum
    2006-04
    1,124
    i thought it was. i also uploaded the block.
    Dynamic Blockhead Mod Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    On first glance everything LOOKS good. looks like everything should be working fine ...... but it's not .... weird.
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
    2006-04
    1,124
    could it have something to do with minimum distances in the array? it is set to an odd fraction...
    i havent really looked at it much in the last day or two, ive been crying in a corner over bidding stuff
    2005-06
    1,828
    i don;t THINK the odd fractions should be an issue ... as long as the size on the block matches what is on the array and parameter properties then it should be good ....
    [SIGPIC][/SIGPIC]
    2008-03
    4
    If you pull the bottom grip on your distance down just slightly, or just increase the height of your distance to something more than 2-43/64, and keep your grip at the top of the brick, the grip stays w/ the top coursing of brick. it seems that somehow the arrays overlap, but i'm just guessing. I don't really know why this works, but it seems to for me: See the attachment.
    2006-04
    1,124
    i had forgotten about this. we re-visited the block and changed the array number to 8/3 and it seems to be working now - although i havent had a chance to use it in a while.
  1. Stretching problems
    By louis.64641 in forum AutoCAD General
    Last Post: 2010-01-08, 02:51 PM
  2. stretching problem
    By Macieto in forum Dynamic Blocks - Technical
    Last Post: 2009-09-02, 07:19 AM
  3. stretching with a fence
    By speet01 in forum AutoCAD General
    Last Post: 2008-05-16, 07:26 PM
  4. Stretching Hatch
    By tiffany.amorgan in forum Dynamic Blocks - Technical
    Last Post: 2007-12-21, 12:46 PM
  5. Stretching Hatch
    By cadmecheng in forum AutoCAD LT - General
    Last Post: 2005-06-22, 08:24 PM
