Thread: can lines be told their elevations from a surface?
    2007-11
    11
    Default can lines be told their elevations from a surface?
    I have a bunch of 2d lines I'd like to follow a surface as their elevation reference. Is there a simple way to do this or do I have to draw all the lines again in 3d?
    2006-12
    Loveland, CO
    734
    Default Re: can lines be told their elevations from a surface?
    Convert them to feature lines. When converting them, there is an option to get the elevations from a surface. If they need to be 3D polylines, you could then explode (I know, can you believe I'm actually suggesting this?) back down to 3D polylines.
    Brian J. Hailey PE
    CAD-1
    Civil3D PLUS My blog
    At Your Desk Training
    2005-08
    Northern Colorado
    100
    Like Brian suggests, create Feature Lines, then explode.
    Grading>Create Feature Lines from Objects
    Make sure you check the "Assign Elevations" box checked, and choose the surface or grading you wish to obtain elevations from.
    If you do a lot of lines at once, this process can take a bit, so be patient.
    Also, when working with Feature Lines, Save early, and save often.
    2007-11
    11
    Cool, I new there had to be a way. Thanks.
  1. Add Spot Elevations to surface
    By robm in forum VBA/COM Interop
    Last Post: 2008-06-24, 10:33 PM
  2. Deleting surface lines also deletes entity lines?
    By jmmacdougall2 in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2008-02-08, 04:25 AM
  3. Deleting surface lines deletes entity lines also?
    By jmmacdougall2 in forum Land Desktop - General
    Last Post: 2008-02-07, 03:08 PM
  4. Export Surface with Z elevations
    By dorseydesignservices in forum AutoCAD Civil 3D - General
    Last Post: 2006-06-20, 08:23 PM
  5. Using Surface to set 'Z' Elevations
    By berniec in forum AutoCAD Civil 3D - General
    Last Post: 2006-05-04, 11:08 AM
