Thread: sun angle not rendering correctly
    2005-12
    134
    Default sun angle not rendering correctly
    when i render the view with the view settings shown in the attached doc and the rendering settings set to use the view settings for shadow, revit shows the shadows wrong... two projects are currently doing this. it seems like it ignores the view setting no matter what i do.
    2005-12
    134
    Default Re: sun angle not rendering correctly
    top left is picked in both dialogue boxes and the shadows are correct in shaded view. the interupted rendering in the background shows the shadows from the upper right. since i've picked the checkbox 'relative to view' and upper left, true north shouldn't be a factor in the rendering, right?
    AUGI Addict truevis's Avatar
    2004-07
    Massachusetts, USA
    1,191
    There's a render setting whether to use the sun settings from view or not.
    2005-12
    134
    i've added a screen shot of the settings dialogue so you can see that i've told it to use the settings from the view. if i've told revit to use the views shadow settings then the shadows should be the same wether i'm looking at a shaded or raytraced shot but they are opposite. we have two files doing this right now. i've tried hitting the 'reset' button and picking the 'upper left' option but it still renders the sun from the upper right.
    All AUGI, all the time gwnelson's Avatar
    2003-04
    Westchester County, NY, USA
    612
    I've had trouble using the sun settings from the view so I uncheck that box & enter what I want to see in the SUN tab. Elevation/Azimuth & Compass views - just grab the arrow head & rotate.
  1. Render is not rendering materials correctly
    By prowley459709 in forum AutoCAD 3D (2007 and above)
    Last Post: 2013-12-13, 10:09 PM
  2. 2013: Family Material Still Not Rendering Correctly in Model
    By bwilliams133 in forum Revit Architecture - Families
    Last Post: 2013-10-11, 08:25 PM
  3. 2013: CCTV Camera Angle Rendering - Possible?
    By kellya29707598 in forum Revit - Rendering
    Last Post: 2013-06-20, 07:30 PM
  4. topography not rendering correctly
    By neb1998 in forum Revit - Rendering
    Last Post: 2005-07-09, 01:43 AM
  5. topography not rendering correctly
    By neb1998 in forum Revit Architecture - General
    Last Post: 2005-07-08, 10:38 PM
