AutoCAD toolbar icons are now stored in the acadbtn.xmx file. Is there any way to extract and edit these Icons? The AutoCAD image editor will only edit/save the 16 bit files. I would like to extract copies of the 32 bit image files to edit.
Yes you can do this. In the AutoCad editor, click edit then save as. save it to the file you want and then you can edit that BMP image in the editor of your choice.
AutoCAD editor only works with 16x16 images. I want to be able to edit the 32x32 images.
Google "resource hacker". It may help. (It may not.)
