Results 1 to 10 of 12
Thread: Color Dialog in VBA
    100 Club KevinBarnett's Avatar
    2001-10
    Pretoria, South Africa
    119
    Question Color Dialog in VBA
    Greetings Gang,
    Is there a way to call the color dialog in Acad 2005's VBA?
    I am still using the VLAX class to call the dialog in lisp - I hope this isnt the only way.
    TIA,
    Kevin.
    Turlock, CA
    6,420
    Default Re: Color Dialog in VBA
    Here's two different methods.
    Public Function AcadColorDialog() As Integer
        'calls the acad color dialog and returns
        'the index of the color selected or -1 if cancelled
        Dim i As Integer
        Dim vl As New VLAX
        'call color dialog
        vl.EvalLispExpression ("(setq clr (acad_colordlg 1))")
        'if dialog was canceled, clr will be nil, set to -1 instead
        i = vl.EvalLispExpression("(if (= clr nil)(setq clr -1)(setq clr clr))")
        AcadColorDialog = i
        Set vl = Nothing
    End Function
    Public Function AcadFileDialog(DlgTitle As String, _
                    Optional DefaultFile As String = "", _
                    Optional Ext As String = "*", _
                    Optional Flag As Integer = 0) As String
        'calls the acad file dialog and returns
        'the file name or a null string "" if cancelled
        'for a list of available flags, see help for (getfiled).
        Dim strFileName As String
        'store current sysvar value
        strFileName = ThisDrawing.GetVariable("USERS5")
        'call color dialog
        ThisDrawing.SendCommand ("(setq fn (getfiled """ & DlgTitle & _
            """ """ & DefaultFile & """ """ & Ext & """ " & Flag & "))" & vbCr)
        ThisDrawing.SendCommand ("(if (= fn nil)" & _
                                 "(setvar ""USERS5"" """")" & _
                                 "(setvar ""USERS5"" fn))" & vbCr)
        AcadFileDialog = ThisDrawing.GetVariable("USERS5")
        'reset sysvar
        ThisDrawing.SetVariable "USERS5", strFileName
    End Function
    C:> ED WORKING....
    LinkedIn
    2006-01
    9
    Well, when I start macro it says:
    'User-defined type not defined.'
    'DIM vl As New VLAX'
    Maybe I need to add Reference?
    I'm using Civil3D 2007, WinXP SP2
        Dim i As Integer
        Dim vl As New VLAX
        'call color dialog
        AcadColorDialog = i
        Set vl = Nothing
    End Function
        'call color dialog
        'reset sysvar
    End Function
    Turlock, CA
    6,420
    Search this forum for "vlax.cls". Its a class that allows you to execute lisp from vba.
    C:> ED WORKING....
    LinkedIn
    2006-01
    9
    Thanks!
    Works fine!
    Can You give me brief axplanation haw to call a lisp dialog
    and retrieve data from it in VBA?
    I sow the functions of VLAX but I'm new to Lisp.
    Turlock, CA
    6,420
    Its much easier to use a vba form.
    C:> ED WORKING....
    LinkedIn
    2006-01
    9
    Ok, I agree!
    But, look of the form designed in VBA is poor against the look of the dcl dialog.
    Dcl is more CAD-like.
    Earth
    9,805
    If you want to avoid using "SendCommand", try this.
    PHP Code:
    Public Declare Function acedSetColorDialog Lib "acad.exe" (color As LongByVal bAllowMetaColor As BooleanByVal nCurLayerColor As Long) As Boolean
    Sub example_usage
    On Error Resume Next
     Dim blnMetaColor
    As Boolean
     Dim lngCurClr
    As Long
     Dim lngInitClr
    As Long
    If acedSetColorDialog(lngInitClrblnMetaColorlngCurClrThen
        MsgBox lngInitClr
     End
    If
    End Sub
    R.K. McSwain | CAD Panacea |
    Turlock, CA
    6,420
    Quote Originally Posted by branimirj View Post
    I didn't know there was such a thing as "CAD-like". AutoCAD is a Windows program and vba uses Windows controls. You can design a dialog to look like dcl if you choose to.
    Anyway, I haven't tried calling a dcl dialog directly from vba. It works on lisp reactors. So it would probably be simplest to have a lisp front-end to the dialog, i.e. instead of calling the dialog from vba, create a function that calls it and returns a value. Then you can call that function from vba. However,
    C:> ED WORKING....
    LinkedIn
    2006-01
    9
    Cheers!
    Well I'll try to explain what I meant by the CAD-like form.
    There are rounded corners in the frame, while line and text are colored.
    When you move the mouse near form object (CheckBox for example) it appears colored and so on (like rollover effect on web page).
    In VBA forms there are no such stuff.
    Background story of the idea is to use dlg instead of VBA forms.
    In routine that I created in VBA (it was finished and works fine), there are a lot of user inputs and I spend lots of time to design well organized form.
    For example when I take a look at the Plot Dialog, it has many information on it and they are still well organized. I think maybe I will achieve the same result by using dlg dialogs.
    I can send You screens to see what I mean, if You are interested.
  1. Calling Revit's native color dialog
    By some buddy in forum Revit - API
    Last Post: 2009-10-08, 02:18 PM
  2. Color dialog - highlight box system variable?
    By Coolmo in forum AutoCAD General
    Last Post: 2006-03-22, 12:59 AM
  3. Color Dialog Box Not Showing Up.
    By tmccoy in forum AutoCAD General
    Last Post: 2006-01-07, 01:17 AM
  4. MTEXT dialog box background color
    By ldibenedetto in forum AutoCAD Wish List
    Last Post: 2005-01-31, 01:20 PM
