Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Color Dialog in VBA
  1. #11
    Turlock, CA
    6,420
    Default Re: Color Dialog in VBA
    Quote Originally Posted by branimirj View Post
    Well I'll try to explain what I meant by the CAD-like form.
    There are rounded corners in the frame, while line and text are colored.
    When you move the mouse near form object (CheckBox for example) it appears colored and so on (like rollover effect on web page).
    In VBA forms there are no such stuff.
    Have you looked at the properties for the form controls? While the default checkbox doesn't have a MouseOver event, it does have other mouse events. There are other controls available on the internet. Additionally, you can make your own with VB6.
    As for the other properties you describe, check out the BorderStyle and SpecialEffect properties. You can make them look exactly like dcl boxes.
    C:> ED WORKING....
    LinkedIn
  2. #12
    Turlock, CA
    6,420
    If you want to avoid using "SendCommand", try this.
    PHP Code:
    Public Declare Function acedSetColorDialog Lib "acad.exe" (color As LongByVal bAllowMetaColor As BooleanByVal nCurLayerColor As Long) As Boolean
    Sub example_usage
    On Error Resume Next
     Dim blnMetaColor
    As Boolean
     Dim lngCurClr
    As Long
     Dim lngInitClr
    As Long
    If acedSetColorDialog(lngInitClrblnMetaColorlngCurClrThen
        MsgBox lngInitClr
     End
    If
    End Sub
    Update: For using with current AutoCAD, You need to add PtrSafe and change exe to accore.dll.
    PHP Code:
    Public Declare PtrSafe Function acedSetColorDialog Lib "accore.dll" (color As LongByVal bAllowMetaColor As BooleanByVal nCurLayerColor As Long) As Boolean
    C:> ED WORKING....
    LinkedIn
  1. Calling Revit's native color dialog
    By some buddy in forum Revit - API
    Last Post: 2009-10-08, 02:18 PM
  2. Color dialog - highlight box system variable?
    By Coolmo in forum AutoCAD General
    Last Post: 2006-03-22, 12:59 AM
  3. Color Dialog Box Not Showing Up.
    By tmccoy in forum AutoCAD General
    Last Post: 2006-01-07, 01:17 AM
  4. MTEXT dialog box background color
    By ldibenedetto in forum AutoCAD Wish List
    Last Post: 2005-01-31, 01:20 PM
