I am working on a multistory project which involves sloping walls which r curved in cross section i.e. top at 20th floor is almost 2m inside than the bottom. The side walls r vertical. I have placed a curved sloping glazed roof on top.
I have done this using massing & than placing elements. The problem is in the cross section. The wall extends above the roof & I am not able to edit the wall-roof junction in section. This wall does not behave like a regular wall. How do i apply attach to roof command to this wall?
Is this the disadvantage of directly applying elements to the massing surface? I know that i can create the same wall using the sweep command but if the massing geometry is complex than this method is cumbersome.
Also the slabs extend beyond the surface of wall. I have to edit each one of them in respective plans. Let me know what is the smartest way of tackling these problems.
