Thread: Plotting multiple design options
    2007-06
    286
    Default Plotting multiple design options
    Hey,
    Did a quick search and didn't come across an asnwer. I have multiple design options that I would like to plot out in one sheet set. Whats the best way of doing this.
    Currently I have just one sheet that I plot and change primary design option before plotting. I don't like this as then the sheet name and number are the same unless I go and change those over and over and over.
    I noticed you can change the visibility of a sheet to show which design option, but that change seemed to have no affect. The only other thing was I could select on the view and do the same be deciding which design option to show without haveing to change the primary. This is great up to where I can't have the same view on multiple sheets. So I stuck to having only one sheet again and then switching the primary option back and forth.
    What have you come up with?
    2003-08
    Vancouver, BC Canada
    3,420
    Default Re: Plotting multiple design options
    By default views will display the <primary> design option. You can override what the view displays from the visibility/graphics dialogue.
    Create duplicate views as required (elevations, sections, 3D etc.) and name them for each design option. Access the V/G dialogue box and you should see a Design Option tab. Select that tab and change the visibility setting from <primary> to the preferred design option for each of the duplicate views. You can then drop each view on asheet as required.
    ____________________________
    Dimitri Harvalias LEED AP
    Summit BIM Consulting
    BIMblog.ca
    I was never just a CAD monkey, so I refuse to be a BIMpanzee!
    A BIM without the 'I' is just a BM - those in the medical profession know what that amounts to
    2007-01
    455
    Hello,
    Duplicate your view (with detailing), make one view for each design option.
    Under Visibility / Graphics (shortcut VG), click on the "Design Options" tab. Then you can set each of the duplicated view to show a different design option.
    Place the different views on sheets.
    Good luck!
    Bryan
    2007-06
    286
    totally overlooked that possibility. I had it figured out, just didn't put the duplicating view together. It shows you need more than 3 hrs of sleep to function.
    Thanks guys!
  1. Multiple Design Options - Help!
    By jayc in forum Revit Architecture - General
    Last Post: 2008-12-18, 03:20 PM
  2. Multiple design options
    Last Post: 2007-12-06, 09:24 PM
  3. Design process: Design options and Worksets.
    By Gordon.Price in forum Revit Architecture - General
    Last Post: 2007-09-11, 08:44 PM
