Thread: Mapguide - Object align="middle"
    2003-03
    Default Mapguide - Object align="middle"
    Sorry if this is the wrong forum, but I couldn't locate one that is more appropriate. If you know of a better forum for Mapguide, Please let me know...
    It's been a while since I've worked with our Mapguide code. Our website now has all the pages centered in the browser window, but I can't figure out how to get the Mapguide Window to be centered. I've tried using the object's 'align' property. It seems to recognize "right" but not "center" or "middle". I'm using version 6.3. I also tried nesting it in a table, but then it doesn't display at all.
    2015-12
    Arizona
    2,478
    Default Re: Mapguide - Object align="middle"
    From the sample code shown here:
    http://usa.autodesk.com/adsk/servlet...linkID=2733874
    For tuning off the border ( I know not the same issue)
    <OBJECT ID="map" WIDTH="500" HEIGHT="250" ALIGN="baseline"
    CLASSID="CLSID:62789780-B744-11D0-986B-00609731A21D"
    It would apear that you would need to change baseline to centered.
    Perhaps post your resultant code for what you have that does work
    even with the wrong alingment, so that we can poke at it to see if it
    will twitch.
    2001-05
    Austin, TX USA
    2,201
    Moved this thread to the BRAND SPANKING NEW MapGuide forum.
    2015-12
    Arizona
    2,478
    I'm waiting for the user to post their data.....
  1. 2015: What determines instance parameter grip "snap" and "align" behavior?
    Last Post: 2019-05-20, 08:45 PM
  2. Replies: 13
    Last Post: 2015-01-26, 01:35 PM
  3. 2012: Align Parameter: making text "Plan Readable"
    By kknauss in forum Dynamic Blocks - Technical
    Last Post: 2013-11-07, 06:40 PM
  4. Problemas com escada "middle stinger"
    By raulpr347843 in forum Revit - Platform
    Last Post: 2013-03-25, 05:44 PM
  5. Mapguide - Object align="middle"
    By dlc in forum AutoCAD Map 3D - General
    Last Post: 2004-09-02, 04:11 PM
