Hi,
Hope someone can help, this has me scratching my head...
Is there a way of accessing the battman commands functionality through VBA?
I've got a hundred or so drawings where I need to modify block attribute tag strings (i.e. change the name of the attribute) for all blocks in a drawing.
I've written a vba routine which will change the tags in all block references, which seems pretty straightforward, but I need to change the tag strings in the block definitions otherwise they could be changed back if blocks are sync'ed at any point.
I've used the GetAttributes method for BlockRef objects, but can't see how to do this for Block objects and the Blocks collection.
Can anyone help?
Thanks
Simon
