Thread: Elevators - Two sided Opening
    2005-11
    175
    Default Elevators - Two sided Opening
    Hi
    How does one model an elevator with wall openings on two opposite sides? Using the wall based elevator in the library, we are able to only provide openings on one side.
    thanks
    Winn
    I could stop if I wanted to mruehr's Avatar
    2004-01
    Perth
    223
    Default Re: Elevators - Two sided Opening
    i use a separate plain elevator door
    as at times we need to avoid the second door on other floors
    the line-work for the elevator family is changed to reflect the thru elevator
    Member DigiPara's Avatar
    2010-06
    Frechen, Germany
    5
    Hi,
    just use Elevatorarchitect, a free plug-in to model an elevator inside Revit. After choosing the elevator you need you can easily select in the settings where you would like to have wall openings, in the rear, front, or both. the plug-in is available as free download at http://www.digipara.com/DownloadEARevit.aspx.
    Karin
  1. Elevators W/ Entries On Opposite Sides
    By TerribleTim in forum Revit Architecture - Families
    Last Post: 2012-12-04, 04:36 PM
  2. 2012: Labeling elevators
    By damon.sidel in forum Revit Architecture - General
    Last Post: 2012-08-01, 05:47 PM
  3. Best Practice: Elevators
    By Gordon.Price in forum Revit Architecture - General
    Last Post: 2011-05-13, 06:58 PM
  4. Elevators - What Category?
    By saeborne in forum Revit Architecture - General
    Last Post: 2008-04-15, 12:02 AM
  5. Service Elevators/Front and Rear Elevators
    By sbrown in forum Revit Architecture - Families
    Last Post: 2004-11-22, 08:15 PM
