Thread: AcadDoc.lsp
    2004-12
    80
    Default AcadDoc.lsp
    I want to set the command "-scalelistedit" to run every time a file is opened. This is the set of commands I want CAD to execute upon opening:
    -scalelistedit
    r
    y
    e
    That will run scalelistedit from the command line, R for RESET, Y for YES, E for EXIT. I tried creating a acaddoc.lsp file to do it that way but I can't seem to get it to work. Can someone explain what is my best option for accomplishing this?
    Thanks
    2003-12
    Pittsburgh, PA
    355
    Default Re: AcadDoc.lsp
    Put this line in your acaddoc.lsp file
    (command "-scalelistedit" "r" "y" "e")
    not tested
    150700
    3,439
    Quote Originally Posted by Shizzjr View Post
    -scalelistedit
    r
    y
    e
    Thanks
    A quick way to test what you were given by lpseifert is to copy (command "-scalelistedit .... ) to your command line and see if does what you want it to do
    Earth
    9,805
    Exclamation Re: AcadDoc.lsp
    Quote Originally Posted by lpseifert View Post
    not tested
    Or better yet...
    (command "._-scalelistedit" "_r" "_y" "_e")
    While were are here, use this for a Menu Macro: ^c^c._-scalelistedit;_R;_Y;_E;
    R.K. McSwain | CAD Panacea |
    0,0,0 The Origin
    8,570
    Just for completeness - your original format is correct for a script.
  1. where did acaddoc.lsp go?
    By cwjean76 in forum AutoLISP
    Last Post: 2010-09-22, 08:28 PM
  2. acaddoc.lsp
    By ted.evans in forum AutoCAD General
    Last Post: 2010-01-22, 07:10 PM
  3. ACADDOC.LSP
    By dbrownson in forum AutoLISP
    Last Post: 2008-02-06, 04:52 AM
  4. acaddoc.lsp?
    By Spanky in forum AutoLISP
    Last Post: 2008-01-27, 01:30 PM
