jhniopek
I imported (drafting views) some standard details that I have in a separate "project". The standard details have all been based on dwg files which have been "partially exploded".
I imported to many of them so I delete the drafting views I didn't need but I can still see the dwg file in Object Styles/ Imported Objects. The dwg files were never linked in to the "detail project".
I am fairly certain that I don't have the dwg files in any other views as they only showed up in Styles/ Imported Objects after I imported the drafting views. As a test I delete all my drafting views - did a Purge All and they are still in Object Styles/ Imported Objects.
When I select an imported object under Object Styles the delete option is greyed out but I can delete the layers/sub categories.
Another question: When I create my Standards details and after I have imported my dwg I partially explode it to tidy it up. After it has been partially exploded is there any way you can remove the imported dwg file? As it has been partially exploded you can't select it and delete it. Please see attached file where I have imported a dwg file and partially exploded it.
I hope it all makes sense.
Thanks
Jonas
