Thread: arch top door
    2006-04
    149
    Default arch top door
    I created a square panel door that has a profile around the edge of the panel (CIW 270-01-A). With the help of a friend, I also have created the same door with an arched top (CIW 270-01-B). The square top works great, the problem is on the arch top door; Revit will not create the sweep profile. I don't know if the issue is that Revit will not create a solid sweep along an arch or if it's becuase there is a formula associated with the length of the side panels.
    The radius of the arch never changes; the spring line moves up or down depending on the width of the door, so we had to create the formula to handle that.
    Is there a different way I have to make the sweep since it's on an arch?
    AUGI Addict Andre Carvalho's Avatar
    2006-06
    Toronto, ON
    2,386
    Default Re: arch top door
    Quote Originally Posted by thomasf View Post
    I've recreated the sweep in both doors using sketch 2D path rather than pick path. Then I locked it. Even the door without the arched top wasn't working properly when loaded into a project, because the sweep wasn't locked to anything. Flexing the door would cause it to stay away from the door panel.
    See attached the corrected files.
    Andre Carvalho
    2006-04
    149
    Thanks Andre; I hadn't noticed that about the non-arched door. I have 3 versions of it with 1, 2 & 3 panels. The 3 panel works fine in my project; I'll have to go back & see what I did differently in that one.
  1. 2013: Revit Arch 2013 - Door Swing Question
    By ROBP-RDS in forum Revit Architecture - Families
    Last Post: 2014-06-22, 03:22 PM
  2. 2012: RCP of linked arch model - show door swings?
    By mattw in forum Revit MEP - General
    Last Post: 2013-04-22, 07:37 PM
  3. door family (ARCH/STRUCT problem)
    By btrusty in forum Revit Architecture - General
    Last Post: 2009-09-16, 09:24 PM
  4. arch door?
    By ebaltierrez in forum ACA General
    Last Post: 2008-08-28, 01:53 PM
