Results 1 to 8 of 8
Thread: join all lines
    2006-03
    13
    Default join all lines
    Is there a way once i have all my lines drawn that I can join them together?
    is there a mass join command?
    the drawing of the lines is done thru vba.
    i know you can use pedit while in autocad and can join lines
    but i need to do this thru vba.
    thanks in advance
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,269
    Default Re: join all lines
    Try this one
    Function Is2DPointsEqual(p1 As Variant, p2 As Variant, gap As Double) As Boolean
         Is2DPointsEqual = False
         Dim a, b
         a = Abs(CDbl(p1(0)) - CDbl(p2(0)))
         b = Abs(CDbl(p1(1)) - CDbl(p2(1)))
         If a <= gap And b <= gap Then Is2DPointsEqual = True
         End Function
    Sub JoinLines()
    ' based on idea by Norman Yuan
    ' Fatty T.O.H. () 2007 * all rights removed
    ' edited 02.04.2008
    Dim oSsets As AcadSelectionSets
    Dim pSset As AcadSelectionSet
    Dim oSset As AcadSelectionSet
    Dim setName As String
    Dim fType(0) As Integer
    Dim fData(0) As Variant
    Dim varPt As Variant
    Dim pickPt As Variant
    Dim fLine As AcadLine
    Dim oLine As AcadEntity
    Dim oEnt As AcadEntity
    Dim commStr As String
    Dim stPt(1) As Double
    Dim endPt(1) As Double
    Dim dxftype, dxfcode
    Dim n As Integer
    Dim sp As Variant
    Dim ep As Variant
    Dim ps(1) As Double
    Dim pe(1) As Double
    Dim vexs As Variant
    Dim oSpace As AcadBlock
    With ThisDrawing
       If .ActiveSpace = acModelSpace Then
          Set oSpace = .ModelSpace
       Else
          Set oSpace = .PaperSpace
       End If
    End With
    On Error GoTo Error_Trapp
    Dim osm
    osm = ThisDrawing.GetVariable("OSMODE")
    ThisDrawing.SetVariable "OSMODE", 1
    ThisDrawing.SetVariable "PICKBOX", 1
    pickPt = ThisDrawing.Utility.GetPoint(, vbCr & "Select the starting point of the chain of lines :")
    ZoomExtents
    Set oSsets = ThisDrawing.SelectionSets
    fType(0) = 0: fData(0) = "LINE"
    dxftype = fType: dxfcode = fData
         setName = "FirstLine"
              With ThisDrawing.SelectionSets
                   While .Count > 0
                        .Item(0).Delete
                   Wend
              End With
         setName = "LineSset"
    Set pSset = oSsets.Add("FirstLine")
    pSset.SelectAtPoint pickPt, dxftype, dxfcode
    If pSset.Count > 1 Then
    MsgBox "More than one line selected" & vbCr & _
    "Error"
    Exit Sub
    ElseIf pSset.Count = 1 Then
    Set fLine = pSset.Item(0)
    ElseIf pSset.Count = 0 Then
    MsgBox "Nothing selected" & vbCr & _
    "Error"
    Exit Sub
    End If
    sp = fLine.StartPoint
    ep = fLine.EndPoint
    ps(0) = sp(0): ps(1) = sp(1)
    pe(0) = ep(0): pe(1) = ep(1)
    If Is2DPointsEqual(pickPt, ps, 0.01) Then
    stPt(0) = ps(0): stPt(1) = ps(1)
    endPt(0) = pe(0): endPt(1) = pe(1)
    ElseIf Is2DPointsEqual(pickPt, pe, 0.01) Then
    stPt(0) = pe(0): stPt(1) = pe(1)
    endPt(0) = ps(0): endPt(1) = ps(1)
    End If
    Dim oPline As AcadLWPolyline
    Dim coors(3) As Double
    coors(0) = stPt(0): coors(1) = stPt(1)
    coors(2) = endPt(0): coors(3) = endPt(1)
    Set oPline = oSpace.AddLightWeightPolyline(coors)
    pSset.Delete
    Set pSset = Nothing
    Set oSset = oSsets.Add("LineSset")
    Dim remLine(0) As AcadEntity
    Set remLine(0) = fLine
    oSset.Select acSelectionSetAll, , , dxftype, dxfcode
    oSset.RemoveItems remLine
    fLine.Delete
    Dim i As Long
    i = 1
    Dim Pokey As Boolean
    Pokey = True
    Do Until Not Pokey
        Pokey = False
    Gumby:
    For n = oSset.Count - 1 To 0 Step -1
    Set oLine = oSset.Item(n)
    sp = oLine.StartPoint
    ep = oLine.EndPoint
    If Is2DPointsEqual(ps, endPt, 0.01) Then
    i = i + 1
    oPline.AddVertex i, pe
    Set remLine(0) = oLine
    oLine.Delete
    vexs = oPline.Coordinate(i)
    endPt(0) = vexs(0): endPt(1) = vexs(1)
    Pokey = True
    Exit For
    ElseIf Is2DPointsEqual(pe, endPt, 0.01) Then
    i = i + 1
    oPline.AddVertex i, ps
    oLine.Delete
    Pokey = True
    Exit For
    End If
    Next n
    If oSset.Count > 0 Then
    GoTo Gumby
    Else
    Exit Do
    End If
    Loop
    oSset.Delete
    Set oSset = Nothing
    Error_Trapp:
    ZoomPrevious
    If Err.Number <> 0 Then
    MsgBox "Error number: " & Err.Number & vbCr & Err.Description
    End If
    On Error Resume Next
    ThisDrawing.SetVariable "OSMODE", osm
    ThisDrawing.SetVariable "PICKBOX", 4 '<--change size to your suit
    End Sub
    ~'J'~
    Turlock, CA
    6,419
    If you are drawing the lines in vba, just keep track of the last object you created and add to it. You say you are drawing lines. Use the endpoint of the last object as the startpoint of the next one. If you need to work with plines, keep that and add to its vertices.
    C:> ED WORKING....
    LinkedIn
    2006-03
    13
    sounds like I should be using a polyline instead of drawing indivadual lines.
    thru vba when using a polyline to draw with how do you go from a straight line to an arc?
    2007-06
    97
    Look at the "SetBulge" method - unfortunately it is not particularly intuitive (neither, for that matter, are polylines in general). If you encounter trouble, post a follow up as someone here is bound to have a suggestion.
    AUGI Addict MikeJarosz's Avatar
    2015-10
    New York NY
    1,497
    Quote Originally Posted by seant61 View Post
    You can say that again, Sean. You saved me twice when I needed the z coordinate of a poly vertex.
    2007-06
    97
    Mike, as I recall you were working on some intersting projects at the time. There was a revamp of a "Sun angle analysis" routine. How goes the progress on that? Also, there was a rather complex sculptured roof, I don't suppose they've broke groun-, uhm, . . . .sky . . . . on that project yet, have they?
    2015-10
    New York NY
    1,497
    I got all the subroutines written... cross product, dot product, parrallelopiped etc, etc, etc, but the routine that connects them all never happened. I was reassigned to Revit API development, something I really wanted to do. Since we already have a system running in LISP, we decided I should spend my time doing something we don't already have.
  1. how to join lines between two junctions?
    By einbauen364392 in forum AutoCAD General
    Last Post: 2012-04-09, 10:18 PM
  2. Join all lines in a drawing
    By elaurier in forum AutoCAD General
    Last Post: 2010-11-05, 02:27 PM
  3. How do I join lines?
    By ukdodger in forum AutoCAD 3D (2006 or below)
    Last Post: 2009-11-10, 02:30 PM
  4. Lines that Join w/o my permission
    By tiffany.amorgan in forum Revit Structure - General
    Last Post: 2006-10-26, 12:14 PM
  5. Join Lines
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2006-10-09, 11:35 PM
