On the current project I'm working on, (15 levels) I have found myself working with two windows. I will model something in plan and verify it in a 3D view. I frequently notice something in 3D from a different level that needs to be adjusted and then don't have a one step way to go to that level's plan.
There are, of course, plenty of ways to figure it out. You can select any slab, or other object and see from the properties window which level it is on, and then switch over to that level. You can visually count up or down from a known level and select it directly in the project browser. On a small project, making the workplane visible might help, etc. etc.
I wish that there were a way to toggle non-printing watermarks on the slabs that have the level names. These could span floor to floor along the enclosure of the structure as well. They could even be hyperlinks to the appropriate plan or elevation just as callouts and section markers are in other types of views.
I also find myself wanting to double click the slab and have the plan open, but I know this is just the CAD talking. It would be nice if hovering over the slab object identified the level instead of just the family.
Can anyone shed some light on best practices or elequent solutions here? It seems like this would be a fairly common desire so am I a missing an obvious tool?
