Page 3 of 9 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 83
Thread: remove data link from drawing??
  1. #21
    2008-10
    Default Re: remove data link from drawing??
    Quote Originally Posted by red2002yzfr1 View Post
    The table is still in the drawing.
    The link is to an excel file.
    My remedy was to use "Spurge" by Manusoft. It found the datalink and I was able to do a "Hard" Purge.
    I was unable to find the link using Spurge OR make use of the lisp routine. When I try DictEdit I receive an error message. I just want these things gone!
  2. #22
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    Congrats on your 1st post, could you give some more info on what error you get? Also what version of AC are you using? Alternatively, could you post the offending DWG?
  3. #23
    2004-11
    4
    any luck using this LISP routine in 2009? wanted to ask before trying it out! =)
  4. #24
    2009-03
    Thumbs up Re: remove data link from drawing??
    Quote Originally Posted by agnethaxoxo View Post
    YES! I just tried and it worked great!
  5. #25
    2009-04
    Hello
    Fantastic LISP! Thank you from Italy
    For delete file .dxe in the CAD 2009 play routin-> save -> close file -> open file
    Bye
  6. #26
    2009-04
    2
    After applying lisp the following message were shown:
    error: bad argument type: consp nil
    but dxe was erased.
  7. #27
    2004-07
    Monterey, Ca
    19
    Bummer. I tried this in 2010 and got this: "; error: quit / exit abort"
    Still searching for a way to remove the links...
  8. #28
    All AUGI, all the time Mlabell's Avatar
    2004-12
    Toledo, OH
    513
    Have you installed the VBA plugin for 2010? The lisp file is calling functions that are vb based. The lisp works like a charm on my 2010 install but I have the VBA plugin installed.
    If that doesnt work which it should do you have the .dcl and .lsp file in your support path?
    Link to plugin
    Hope this helps!
  9. #29
    2004-07
    Monterey, Ca
    19
    I figured it out for 2010. Select the table, then activate one cell, just so the cell has the bold outline on it. Right click on the cell and select "Data Link" then "Detatch Data Link" and "Yes" when prompted. You'll then need to open the Data Link Manager (DATALINK), right click on the link(s) and select Delete. Just be sure all link references have been detatched before opening DATALINK.
    The key is having a cell selected instead of the entire table.
  10. #30
    All AUGI, all the time Capt. Computer Crasher's Avatar
    2006-12
    South of North & East of West
    786
    Quote Originally Posted by seneb View Post
    you do the same thing in 2008 & 2009. you must detach link before deleting it. If you don't the link will stay around
  1. Remove Data Extractions
    By gfreddog in forum AutoCAD General
    Last Post: 2017-02-01, 05:29 PM
  2. Replies: 1
    Last Post: 2015-04-29, 01:18 PM
  3. Remove data from parameter in schedule
    By drewj in forum Revit MEP - General
    Last Post: 2010-11-10, 05:45 PM
  4. Field data lost at data link synchronization
    By brennsvette in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-09-17, 03:07 PM
  5. Remove link from inserted raster images
    By jstdrwit in forum Raster Design - General
    Last Post: 2004-09-30, 07:56 PM
