Thread: FLIP PARAMETER CREATES A SKEW
    I could stop if I wanted to Ammon's Avatar
    2005-06
    Salt Lake City, Utah
    423
    Default FLIP PARAMETER CREATES A SKEW
    OK here's a base plate dynamic block. It's a work in progress. I have a flip parameter that when I set it to the flipped state, it skews the things that it flips. Any help out there?
    2005-06
    423
    Default Re: FLIP PARAMETER CREATES A SKEW
    Actually, I figured it out, like 5 minutes after posting my question. My selection box for a stretch action which included the flip parameter, did not completely include the ends of the flip parameters flip lines. Once I changed this, it was fixed.
    I hope that helped someone else.
    2005-06
    423
    OK, now it's doing something similar and I can't figure out how to fix it this time.
    Change the LOC / ORIENT parameter to ROTATED CORNER, or END, or FLUSH ROTATED CORNER, or FLUSH END
    and then when you:
    • change the ENDWALL parameter (the Flip parameter), the COLUMN DEPTH parameter stretches. If you keep changing it back and forth, the stretch grows.
    • change the SIDEWALL parameter (also a Flip parameter), a really wierd skew happens.
  1. help with a flip parameter
    By LSElite in forum Dynamic Blocks - Technical
    Last Post: 2015-06-28, 10:18 PM
  2. Flip Parameter is Flipping Me Out!
    By jf1725 in forum Dynamic Blocks - Technical
    Last Post: 2009-02-25, 12:31 PM
  3. Exploding dynamic blocks w/ a flip parameter
    By wroebuck in forum Dynamic Blocks - Technical
    Last Post: 2007-12-06, 10:08 PM
  4. Flip parameter and Block xyz scale
    By cadconcepts in forum Dynamic Blocks - Technical
    Last Post: 2007-11-17, 03:56 PM
  5. Keep Text Justification when using the Flip Parameter
    By SRBalliet in forum Dynamic Blocks - Technical
    Last Post: 2007-06-04, 09:00 PM
