Hello AUGI Members,
We are using AutoCAD 2008 and have Oce TDS 600 and 700 plotters. When plotting a drawing that has image files attached with zero (0) fade that images plot perfectly. However, When the image files are adjusted with the Image Fade option to any percentage other than zero the image area plots dark gray. The higher the percent of fade the image plots a darker shade of gray instead of screening or plotting the image that percentage lighter. The goal is to lighten or fade the image so we can draw on top of the image with lines, polylines, text etc...!
Has anyone else experienced this type of problem....?? Am I doing something incorrectly....??
Any recommendations or suggestions on resolving this difficulty will be appreciated...!
Regards,
Vince
