Hi All,
I have block symbols inserted using desc-keys for items such as manholes, fire hydrants, light poles etc as well as point data with no symbols, just point markers and labels for defining the surface. I want to remove all the point data from the drawing but leave all the block symbols in place. Is this possible (similar to LDD). The reason I want to do this is because this drawing is used as an X-Ref background for all the other depts. and therefore there is no need to retain the point data once the final drawing is complete. Is this the right way to go or should I leave the point data intact and just use point groups to display the objects. By the way, I'm the only one who uses Civil 3D, which means no one else has any control over displaying the points other than turning on/off the correct layers, provided I've set everything up correctly.
Cheers.
