Results 1 to 8 of 8
Thread: 3D Feature lines- Change grades
    2003-01
    194
    Angry 3D Feature lines- Change grades
    I am trying to grade a subdivision. I have created a surface from my road and I am now using feature lines created from the assembly along the right of way. I am offseting the feature lines 20' at a 2% slope for the drive ways. It will not keep the grade. In some places it works, in other places it ignores it. I have tried just creating feature lines going at a 2% slope for 20' and it will change the grade to something like 23% once I add it to the surface. How can it just change the grade on a feature line by itself?????
    This is a simple site that has taken me 8 hours instead of 3. UGH!!!!!!!!!!
    All AUGI, all the time brian.hailey933139's Avatar
    2006-12
    Loveland, CO
    734
    Default Re: 3D Feature lines- Change grades
    The first thing that comes to mind is Sites. Do you have alignments, parcels, other feature lines, or grading in the same site as these feature lines?
    Brian J. Hailey PE
    CAD-1
    Civil3D PLUS My blog
    At Your Desk Training
    2008-04
    Cubeland, Indiana
    10
    This happen to me also. It looked like the straight segments had the right elevation but if it had an arc in it, it didn't work. I ended up offsetting the feature line then using the edit feature line command and lowering the elevation of the feature line by the difference and it worked every time. Sorry if my terminology is off, I'm at home away from C3d for a couple of days.
    2008-04
    Quote Originally Posted by jenniferchavez View Post
    get an answer?
    I would have this as part of my assembly!
    if there is some reason you don't won't do do this, try create a curb with a realitive elevation change instead of by slope. more reliable
    i would first look at the elevation editor to see if there is reason for this working some places and not others.
    In this case of creating a feature from a corridor you can dynamically link it back to the corridor. then try grading objects to keep the first twenty feet dynamic.
    for this reason
    2007-09
    Another reason can be settings of the surface build (definition tag in surface properties). When you add feature lines into a surface, whenever a crossing or overlapping of feature lines occur - a solution is needed. 4 options are available:
    1. Will not alow the added feature lines/ breaklines
    2. Use elevation of lastly added feature line(s)
    3. Use elevations of first added feature line(s)
    4. Use average elevations of feature lines at crossing
    In your case, it can be option 3 or option 4 was selected that causes changes in elevations/grades of your feature lines. Also, within one SITE there will be only 1 elevation at one location thus there will be mutual influence between feature lines crossing each other.
    2008-02
    North Liberty
    34
    Quote Originally Posted by nguyenhoangquan View Post
    What style is this definition tag under? Is there a way to disable this need to solve crossing feature lines?
    "Whatever you are, be a good one."
    — Abraham Lincoln
    2001-10
    Arizona
    2,337
    I would stop using the stepped offset for this function,
    and either use an assembly for the driveways added vie the section editor
    or creating a Grading Criteria and grading the driveways in that manner.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    2001-10
    Arizona
    2,337
    Quote Originally Posted by Chud View Post
    Yes in the Surface settings (Build) tab one can allow crossing breakline or in this instance NOT Allow them. Then you will get an error when they occur, and you can resolve them if needed.
    Be your Best,
    Michael Farrell
  1. Surface not updating when feature lines change
    By Anthony Rhodes in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2011-08-01, 03:01 PM
  2. Feature Lines to Zero.
    By wilsonk in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2009-01-15, 09:54 PM
  3. Feature lines
    By wag24 in forum AutoCAD Civil 3D - General
    Last Post: 2008-11-19, 06:09 PM
  4. Feature lines not right.
    By Glenn Pope in forum AutoCAD Civil 3D - Corridors
    Last Post: 2006-07-21, 05:12 AM
