Results 1 to 10 of 11
Thread: Special Layer Freeze LISP Routine
    Member dbanker's Avatar
    2002-12
    Mushroom Capital of the World
    47
    Question Special Layer Freeze LISP Routine
    Would someone be willing to create a LISP routine for me?
    Here's what I need: I need a layer freeze routine that will detect if the selected object is on the current layer, to make layer 0 current and continue to then freeze that layer.
    Possible? I think so, i just don't know enough about LISP to do this.
    Thanks much!!!
    2005-06
    in the upper right corner
    3,507
    Default Re: Special Layer Freeze LISP Routine
    Quote Originally Posted by dbanker View Post
    Thanks much!!!
    Sounds very possible.
    Maybe you can explain a little more, are you looking to freeze a particular layer or just select an object and freeze the layer it's on?
    Or something else?
    Are you looking for something like this?
    (defun c:LFR (/ CLayer$ EntList@ EntName^ Layer$)
      (setq CLayer$ (getvar "CLAYER"))
      (princ "\nSelect object on layer to freeze")
      (if (setq EntName^ (car (entsel)))
        (progn
          (setq EntList@ (entget EntName^))
          (setq Layer$ (cdr (assoc 8 EntList@)))
          (if (and (= Layer$ CLayer$)(/= Layer$ "0"))
            (command ".LAYER" "T" "0" "U" "0" "ON" "0" "S" "0" "")
          );if
          (if (= Layer$ "0")
            (princ "\nCannot freeze layer 0.")
            (command ".LAYER" "F" Layer$ "")
          );if
        );progn
      );if
      (princ)
    );defun c:LFR
    2005-06
    3,507
    Quote Originally Posted by Terry Cadd View Post
        (progn
          );if
          (if (= Layer$ "0")
          );if
        );progn
      );if
      (princ)
    );defun c:LFR
    Nice Terry! I think that's exactly what the OP is looking for.
    I was trying to scab something together, but couldn't make it NOT go to layer zero if it wasn't on the current layer.
    2002-12
    47
    I will try it and let you know. THANKS!
    2002-12
    47
    Smile Re: Special Layer Freeze LISP Routine
        (progn
          );if
          (if (= Layer$ "0")
          );if
        );progn
      );if
      (princ)
    );defun c:LFR
    That work's beautifully! Can i give you credit for it or is it someone elses?
    Again Thanks!
    Thanks Doug! It's a slight modification to the one I have in my tool box. However, I like your version better.
    Another version would be if the object selected was the current layer to have the user select an object on a layer to set current before freezing the layer. Here's the code for that.
    (defun c:LF (/ CLayer$ EntList@ EntName^ Layer$ Loop NewLayer$)
        (progn
          (if (= Layer$ CLayer$)
            (progn
              (princ "\nThat object is on the current layer.")
              (setq Loop t)
              (while Loop
                (princ "\nSelect object on layer to set current")
                  (progn
                    (setq NewLayer$ (cdr (assoc 8 EntList@)))
                    (if (/= NewLayer$ Layer$)
                      (progn
                        (setvar "CLAYER" NewLayer$)
                        (setq Loop nil)
                      );progn
                      (princ "\nThat object is also on the current layer.")
                    );if
                  );progn
                  (setq Loop nil)
                );if
              );while
            );progn
          );if
        );progn
      );if
      (princ)
    );defun c:LF
    2015-11
    Jo'burg SA
    4,512
    And if you use (nentsel instead of (entsel then you can obtain nested entities so it works the same way as the LAYFRZ command. Enabling you to freeze layers contained in XRefs / Blocks by picking the nested entities.
    And then the only portion to change in order to make this work exactly the same as LAYFRZ would be to check if the user's inside a floating viewport & then only freeze as a viewport override instead of freezing throughout the DWG.
    2015-10
    2
    Can this possibly be modified to make layer '0' current and freeze ALL other layers?
    2005-06
    3,507
    Quote Originally Posted by yoong710906 View Post
    If that is all you want to do.. here is a simple lisp that puts you on layer zero and freezes all other layers:
    (defun c:foo ()
    (setq ce (getvar "cmdecho"))
        (setvar "cmdecho" 0)
    	(command "layer" "s" "0" "")
    	(command "layer" "freeze" "*" "" )
    (setvar "cmdecho" ce)
    (princ)
    HTH
  1. LISP routine to overwrite layer descriptions...
    By dortega4269 in forum AutoLISP
    Last Post: 2014-07-23, 08:04 PM
  2. Layer Color Change LISP Routine
    By guardianfiredesign774457 in forum AutoLISP
    Last Post: 2013-08-28, 05:08 AM
  3. Add layer command line to a lisp routine
    By BrianTFC in forum AutoLISP
    Last Post: 2012-02-02, 07:47 AM
  4. Layer Freeze/Thaw toggle routine
    By jgardner.79905 in forum AutoLISP
    Last Post: 2010-02-01, 09:39 PM
  5. Layer creation lisp routine?
    By boeris9333 in forum AutoLISP
    Last Post: 2009-10-05, 11:24 AM
