Thread: Clearance for Interference Checks in Families
    2006-12
    203
    Default Clearance for Interference Checks in Families
    Since we work with architecture and MEP, there are a lot of times that we need to drop in pieces of mechanical equipment into a project and keep a clear space above them for maintenance, etc.
    What I'd like to be able to do is build into, say a boiler family, a clear space from the top of the boiler up about 2' to take up space for an interference check. But I do not want the space to show in my plans, 3d views, etc. So I tried this with a void, then put a floor directly above it by 1 inch.
    I ran an interference check... lo and behold, no interferences detected. Not at all what I expected, since the void is part of the family...
    Sooooo.... how would you recommend that we do this?
    Thank you for your help!
    Revit Technical Specialist - Autodesk Scott Davis's Avatar
    2003-04
    Chino, CA
    4,743
    Default Re: Clearance for Interference Checks in Families
    Use a solid with an on/off parameter and turn it off for normal day to day work. Turn on the solid to run interference checks.
    Scott D Davis
    AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
    NavisWorks Moderator david.kingham's Avatar
    2004-07
    Fort Collins, CO
    1,329
    Here is a simple example of what I do...
    I have visibility turned off in all views except 3d. I always create my clearances as a generic model and create subcategories, then you can turn them off in 3d if needed.
    If the clearance is related to something else like a boiler I would nest the clearance family into the boiler family, this way you can always find the clearances under generic models
  1. 2012: Issues with Fillets, snaps, dimnesion checks
    By mroth3270139 in forum AutoCAD General
    Last Post: 2012-02-06, 08:42 PM
  2. rs2010 consistency checks
    By 777rivendell in forum Revit Structure - General
    Last Post: 2010-01-14, 04:54 AM
  3. Design Checks
    By pat.pennington in forum AutoCAD Civil 3D - Profiles
    Last Post: 2009-01-15, 02:59 PM
  4. Electrical and Interference Checks
    By jwongmep in forum Revit MEP - General
    Last Post: 2008-05-30, 09:10 PM
  5. Interference Checks with Pipes in 2007
    By melanie.santer in forum Civil 3D Tips & Tricks
    Last Post: 2006-08-03, 04:49 PM
