spacedecor
DXB means... DRAWING EXCHANGE BINARY.This method is autocad default plotter output.First you can add with added plotter wizard from your system plotter(must add in autocad plotstyle mananger).This plotter extension is .dxb and you can give proper name.After you plot to file with dxb plotter,you must need to open new drawing.Next you can type "dxbin" in new drawing and you can choose your plot file.Then you can use "overkill" for all object to delete overlap line,arc...etc.And then,you can set drawing unit and limit.Your dxb drawing is need to scale with refrence option.Because this drawing can change all dimension.But they are all same scale original drawing propotion.You can know any dimension from your original drawing.Enjoy it !
