Results 1 to 8 of 8
Thread: Opening multiple drawings in MEP 2008 sp1
    2005-12
    Greeley, CO
    115
    Default Opening multiple drawings in MEP 2008 sp1
    When opening multiple drawings from explorer only about 80% of the drawings actually open. Is there a setting in ACAD that I need to change or is there a workaround? I've tried this which I got from other posts
    "From File Explorer > Tools > Folder Options > File Types > wait, wait some more > highlight DWG in list, > Advanced
    > highlight open > Edit... > (If open isn't there use New.. to create it.)
    Application used to perform action:
    "C:\Program Files\AutoCAD 2008\acad.exe" "%1"
    Use DDE
    checked
    DDE Message:
    [open("%1")]
    Application:
    AutoCAD.r17.DDE"
    But it didn't change anything.
    We just upgraded from 2007 which hasn't been uninstalled.
    Any help would be appreciated.
    0,0,0 The Origin
    8,028
    Default Re: Opening multiple drawings in MEP 2008 sp1
    Hi, Welcome to AUGI.
    Does "80% of the drawings" mean more than one at a time?
    If so, the DDE method is not the problem.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2005-12
    Greeley, CO
    115
    by 80% I mean that if try to open 5 drawings only 4 will open. If I try to open 10 Only 8 will open.
    0,0,0 The Origin
    8,028
    Quote Originally Posted by bearden383 View Post
    I thought so.
    Hmm. I don't know of any acad variable would have that effect.
    I'd guess at (lack of) memory but that wouldn't give a consistent result.
    John B
    2007-05
    Chicago, Illinois
    194
    I've had the same problem in Vanilla AutoCAD. I've just gotten into the habit of opening AutoCAD first and either dragging the files into the program or using the Open menu. It works fine both ways.
    2007-08
    47
    double check your changes
    this is what i have for OPEN action, copy and paste if needed
    "C:\Program Files\Common Files\Autodesk Shared\AcShellEx\AcLauncher.exe" /O "%1"
    [open("%1")]
    AutoCAD.r17.DDE
    blank
    System
  1. Opening multiple drawings from outside AutoCAD
    By Coffee Coffee in forum AutoCAD General
    Last Post: 2010-06-28, 02:51 PM
  2. Opening Multiple Drawings
    By kryptonite_186 in forum AutoCAD General
    Last Post: 2008-03-04, 09:57 PM
  3. Replies: 13
    Last Post: 2008-01-14, 08:58 PM
  4. Opening Multiple Drawings
    By litchfieldl in forum AutoCAD Civil 3D - Land Desktop Companion - General
    Last Post: 2007-09-08, 12:50 AM
  5. AutoCAD LT 2006 - Opening multiple drawings within same session
    By lazer2go in forum AutoCAD LT - General
    Last Post: 2006-11-30, 09:00 PM
