Thread: Find and Replace in AutoCAD 2009
    2008-02
    2
    Exclamation Find and Replace in AutoCAD 2009
    I am having a problem with the find and replace feature in ACAD 2009. The company I work for has some very detailed, sometimes cluttered drawings, and when I type in the text that I am looking for, it zooms in to the peice in question, but when I close the dialog box, the screen zooms back out. Is there a setting that needs to be changed or is there something I'm doing wrong?
    2007-04
    60
    Default Re: Find and Replace in AutoCAD 2009
    To zoom to and highlight each result individually, leave the List Results check box unchecked.
    you will find more results
    double click for each results it will be zoom in
    2005-09
    Thumbs up Re: Find and Replace in AutoCAD 2009
    Service Pack 1 fixes this - the documentation on AutoDesk website doesn't mention this.
  1. Find and Replace command in AutoCAD 2009
    By oskyaqui in forum AutoCAD General
    Last Post: 2009-07-02, 12:13 PM
  2. Comando find en AutoCAD 2009
    By barahona in forum Español - AutoCAD / AutoCAD LT
    Last Post: 2009-01-16, 06:10 PM
  3. AutoCAD Map 2009 Find
    By jludlow in forum AutoCAD Map 3D - General
    Last Post: 2008-08-07, 05:35 PM
  4. Find and Replace
    By U.Rackharrow in forum AutoCAD General
    Last Post: 2007-10-16, 02:44 PM
