Is there a way to make a dialog box appear when opening a drawing?
I need the dialog box to contain some disclaimer text.
Any thoughts our ideas would be appreciated.
That would be cool. The only thing I've seen that comes close is freeze all the layers, and write a disclaimer on one that says something like if you thaw the drawing to use it, we are not responsible for it's contents, etc,etc.
Have the drawing saved so that shows when they open it. Then they thaw the layers and use it.
how do you want it called? if it is based on content in the drawing, this should work:
put it in your acaddoc.lsp, the only problem is, for the disclaimer to appear, the program has to be loaded. If you are sending the drawings out, I dont believe there is a way to get it to show a box on another companies computer.Code:(defun c:disclaimer (/ ss) (if (setq ss (ssget "_X" '((some filter)))) (alert "some message") );end if );end defun
Yeah, I need it to appear in a drawing that i send out.
Sounds like a wish list item!
It's possible -- using VBA and a macro that's embedded in the drawing and set to autorun. essentially you'll be writing a VBA virus that doesn't propogate to other drawings. One step up from malware.....
