Thread: Toolbar has disappeared and unable to get it back
    Question Toolbar has disappeared and unable to get it back
    my draw toolbar suddenly disapeared, and i can not get it back !
    tried to get it back by turning it off then back on (no good)
    tried putting all toolbars in center and checking perimiter (no good)
    tried redos,undos and restarts (no good)
    will try anything ...........any ideas ????????????
    2015-12
    Arizona
    2,478
    Default Re: Toolbar has disappeared and unable to get it back
    Yes, export your current profile to the desktop (saveme.ARG)
    In there when you open it with notepad you will find the location
    of the DRAW tool bar and all others that are open. Delete that line
    then import and set that profile current. You will then be able to right-click
    and select the DRAW toolbar as before. At such time export that profile
    again (to save you in the future) and then delete and recreate the previous profile
    name.
    13,656
    Hi
    Please note I've *moved* this thread from the New Users Forum to this one as I believe it would be better served here.
    Below snippet is taken from the small print found on the Forum General page ( Click HERE to see a screen capture )...
    <snip>
    New users: Please experiment here with forum features and commands.
    </snip>
    Thanks, Mike
    Forum Moderator
    13,656
    Hi
    Check out the following Technical Document on the Autodesk web site under the Knowledge Base section...
    ID: TS19141 - Selected toolbars are not displayed
    Hopefully the solution offered within the above document will get your "draw" toolbar back on screen.
    Have a good one, Mike
  1. Unable to get back to Plan View
    By kane333 in forum AutoCAD 3D (2007 and above)
    Last Post: 2011-05-24, 10:30 PM
  2. Quick Access Toolbar Disappeared
    By christopherr in forum AutoCAD General
    Last Post: 2009-12-14, 09:32 AM
  3. toolbar disappeared
    By fathibaali in forum AMEP General
    Last Post: 2008-09-24, 04:44 PM
  4. Toolbar Disappeared
    By todd.mackay in forum AutoCAD General
    Last Post: 2008-04-01, 12:08 PM
  5. All of my toolbars disappeared, how to get them back
    By robdg in forum AutoCAD Customization
    Last Post: 2006-12-18, 03:11 PM
