is it possible to do so.
could anyone write for me???
find the attached picture for more information.
Is this what you loking for?
~'J'~Code:;;ARL.lsp (defun ltype-load (ltyp) (if (not (tblsearch "ltype" ltyp)) (command "._-linetype" "_l" ltyp (findfile (if (= (getvar "measurement") 0) "acad.lin" "acadiso.lin")) "")) (princ) ) (defun C:ARL (/ ang1 ang2 cent elist en end ent p1 p2 pc start) (ltype-load "CENTER");<--change linetype to suit (setq ltp (getvar "celtype")) (setvar "celtype" "CENTER");<--change linetype to suit (while (setq ent (entsel "\nSelect an arc with accuracy (or press Enter to Exit)>>")) (setq en (car ent) elist (entget en) cent (cdr (assoc 10 elist))) (setq start (vlax-curve-getstartpoint en) end (vlax-curve-getendpoint en) ) (command "._line" "_non" cent "_non" start "" "._line" "_non" cent "_non" end "" ) (setq ang1 (+ (angle cent start)(/ pi 2)) p1 (polar start ang1 1) ang2 (- (angle cent end)(/ pi 2)) p2 (polar end ang2 1) pc (inters start p1 end p2 nil) ) (command "._line" "_non" start "_non" pc "" "._line" "_non" end "_non" pc "" ) ) (setvar "celtype" ltp) (princ) ) (princ "\n *** Type ARL to execute ***") (prin1) (vl-load-com)
exactly
thanks for the lisp
is it possible to do this for mutiple arcs at a single time?
Yes
~'J'~Code:(defun ltype-load (ltyp) (if (not (tblsearch "ltype" ltyp)) (command "._-linetype" "_l" ltyp (findfile (if (= (getvar "measurement") 0) "acad.lin" "acadiso.lin")) "")) (princ) ) (defun C:ARL (/ *error* ang1 ang2 cent elist en end ltp p1 p2 pc sset start) (defun *error* (msg) (if (vl-position msg '("console break" "Function cancelled" "quit / exit abort" ) ) (princ "Error!") (princ msg) ) (if ltp (setvar "celtype" ltp)) (command "._undo" "_e") (princ) ) (command "._undo" "_be") (ltype-load "CENTER");<--change linetype to suit (setq ltp (getvar "celtype")) (setvar "celtype" "CENTER");<--change linetype to suit (if (setq sset (ssget "_:L" (list (cons 0 "ARC")))) (while (setq en (ssname sset 0)) (setq elist (entget en) cent (cdr (assoc 10 elist))) (setq start (vlax-curve-getstartpoint en) end (vlax-curve-getendpoint en) ) (command "._line" "_non" cent "_non" start "" "._line" "_non" cent "_non" end "" ) (setq ang1 (+ (angle cent start)(/ pi 2)) p1 (polar start ang1 1) ang2 (- (angle cent end)(/ pi 2)) p2 (polar end ang2 1) pc (inters start p1 end p2 nil) ) (command "._line" "_non" start "_non" pc "" "._line" "_non" end "_non" pc "" ) (ssdel en sset) ) ) (*error* nil) (princ) ) (princ "\n *** Type ARL to execute ***") (prin1) (vl-load-com)
Code:(defun c:ALS(/ @ltype-load ~OSM ~CMD ~LTP etype ed MP R Ang1 Ang2) (defun @ltype-load (ltyp) (if (not (tblsearch "LTYPE" ltyp)) (command "._-LINETYPE" "_L" Ltyp (findfile (if (= (getvar "MEASUREMENT") 0) "Acad.lin" "Acadiso.lin")) "")) ) (setq ~OSM (getvar "OSMODE") ~CMD (getvar "CMDECHO") ~LTP (getvar "CELTYPE") etype "") (setvar "OSMODE" 0)(setvar "CMDECHO" 0) (ltype-load "CENTER");<--change linetype to suit (setvar "CELTYPE" "CENTER");<--change linetype to suit (while (not (= etype "ARC")) (setq ed (entget (car (entsel)))) (setq etype (cdr (assoc 0 ed))) ) (setq MP (cdr (assoc 10 ed)) R (cdr (assoc 40 ed)) Ang1 (cdr (assoc 50 ed)) Ang2 (cdr (assoc 51 ed))) (command "_.LINE" MP (polar MP Ang1 R) (polar MP (+ Ang1 (/ (- Ang2 Ang1) 2.0)) (abs (/ R (cos (/ (- Ang2 Ang1) 2.0))))) "") (command "_.LINE" MP (polar MP Ang2 R) (polar MP (+ Ang1 (/ (- Ang2 Ang1) 2.0)) (abs (/ R (cos (/ (- Ang2 Ang1) 2.0))))) "") (setvar "CELTYPE" ~LTP)(setvar "OSMODE" ~OSM)(setvar "CMDECHO" ~CMD) (princ) ) (princ "\n *** Type ALS to execute ***")Regards, HofCAD CSI.Code:(defun c:MALS(/ @ltype-load ~OSM ~CMD ~LTP sset i ed MP R Ang1 Ang2) (defun @ltype-load (ltyp) (if (not (tblsearch "LTYPE" ltyp)) (command "._-LINETYPE" "_L" Ltyp (findfile (if (= (getvar "MEASUREMENT") 0) "Acad.lin" "Acadiso.lin")) "")) ) (setq ~OSM (getvar "OSMODE") ~CMD (getvar "CMDECHO") ~LTP (getvar "CELTYPE") etype "") (setvar "OSMODE" 0)(setvar "CMDECHO" 0) (ltype-load "CENTER");<--change linetype to suit (setvar "CELTYPE" "CENTER");<--change linetype to suit (setq i 0 sset (ssget (list (cons 0 "ARC")))) (repeat (sslength sset) (setq ed (entget (ssname sset i))) (setq MP (cdr (assoc 10 ed)) R (cdr (assoc 40 ed)) Ang1 (cdr (assoc 50 ed)) Ang2 (cdr (assoc 51 ed))) (command "_.LINE" MP (polar MP Ang1 R) (polar MP (+ Ang1 (/ (- Ang2 Ang1) 2.0)) (abs (/ R (cos (/ (- Ang2 Ang1) 2.0))))) "") (command "_.LINE" MP (polar MP Ang2 R) (polar MP (+ Ang1 (/ (- Ang2 Ang1) 2.0)) (abs (/ R (cos (/ (- Ang2 Ang1) 2.0))))) "") (setq i (1+ i)) ) (setvar "CELTYPE" ~LTP)(setvar "OSMODE" ~OSM)(setvar "CMDECHO" ~CMD) (princ) ) (princ "\n *** Type MALS to execute ***")
My way ! for arcs and poly-arcis it possible to do this for mutiple arcs at a single time?
Code:(vl-load-com) (defun c:Draw_PolyArc ( / js n ename obj pr typ_obj pt_start pt_end pt_cen rad alpha pt_vtx dist_start dist_end seg_len seg_bulge) (defun grdraw-id_arc ( / ) (grdraw (trans pt_start 0 1) (trans pt_vtx 0 1) 1) (grdraw (trans pt_vtx 0 1) (trans pt_end 0 1) 1) (grdraw (trans pt_start 0 1) (trans pt_cen 0 1) 3) (grdraw (trans pt_cen 0 1) (trans pt_end 0 1) 3) ) (princ "\nSelect Arcs/PolyArcs .") (setq js (ssget '((-4 . "<OR") (-4 . "<AND") (0 . "POLYLINE") (-4 . "<NOT") (-4 . "&") (70 . 126) (-4 . "NOT>") (-4 . "AND>") (0 . "LWPOLYLINE,ARC") (-4 . "OR>")) ) n -1 ) (cond (js (repeat (sslength js) (setq ename (ssname js (setq n (1+ n))) obj (vlax-ename->vla-object ename) pr -1 ) (setq typ_obj (vla-get-ObjectName obj)) (if (eq typ_obj "AcDbArc") (progn (setq pt_start (vlax-get obj 'StartPoint) pt_end (vlax-get obj 'EndPoint) pt_cen (vlax-get obj 'Center) rad (vlax-get obj 'Radius) alpha (* (vlax-get obj 'TotalAngle) 0.5) pt_vtx (polar pt_cen (+ (vlax-get obj 'StartAngle) alpha) (+ rad (* rad (1- (/ 1 (cos alpha)))))) ) (grdraw-id_arc) ) (repeat (fix (vlax-curve-getEndParam obj)) (setq dist_start (vlax-curve-GetDistAtParam obj (setq pr (1+ pr))) dist_end (vlax-curve-GetDistAtParam obj (1+ pr)) pt_start (vlax-curve-GetPointAtParam obj pr) pt_end (vlax-curve-GetPointAtParam obj (1+ pr)) seg_len (- dist_end dist_start) seg_bulge (vla-GetBulge obj pr) ) (if (not (zerop seg_bulge)) (progn (setq rad (/ seg_len (* 4.0 (atan seg_bulge))) alpha (+ (angle pt_start pt_end) (- (* pi 0.5) (* 2.0 (atan seg_bulge)))) pt_cen (polar pt_start alpha rad) pt_vtx (polar pt_start (- alpha (* pi 0.5)) (* rad (/ (sin (* 2.0 (atan seg_bulge))) (cos (* 2.0 (atan seg_bulge)))))) ) (grdraw-id_arc) ) ) ) ) ) ) ) (prin1) )
Thanks for your replies
