Thread: AutoCAD 2009 - Show full path and file name in the bar at the top of the opening screen
    2004-06
    Slidell, Louisiana
    972
    Default AutoCAD 2009 - Show full path and file name in the bar at the top of the opening screen
    Does anyone know if there is a lisp file or plugin to show the full path and file name of the current dwg in the bar at the top of the opening screen. I had this for 2008 and it comes in very handy.
    0,0,0 The Origin
    8,570
    Default Re: AutoCAD 2009 - Show full path and file name in the bar at the top of the opening screen
    Type CONFIG.
    "Open and Save" tab - check "Display full path in title" box.
    2004-06
    Slidell, Louisiana
    972
    Thanks Jaberwok, that did the trick.
    2006-12
    Big "D"
    3,711
    Now if they could only have it so you could move it left, right, or centered, it'd be perfect! Having it in the center sucks for dual monitors.
    2008-01
    0,0,0 The Origin
    8,570
    Quote Originally Posted by dzatto View Post
    Do you spread acad's base window across both monitors?
  1. 2016: Autocad Arch 2016 Floating File Path on screen
    By janderson664783 in forum ACA General
    Last Post: 2015-08-12, 02:11 PM
  2. Opening a dwg file in AutoCAD Civil 3D 2009
    By jkage in forum AutoCAD Civil 3D - General
    Last Post: 2008-08-18, 01:23 PM
  3. AutoCAD 2009 - Full Path in Title Bar
    By mockdeep in forum AutoCAD General
    Last Post: 2008-07-17, 12:18 PM
  4. Full File Path in Window Title Bar
    By Dimitri Harvalias in forum Revit - Platform
    Last Post: 2008-02-13, 10:08 PM
  5. full path of file
    By cheukling125525.110216 in forum Revit Architecture - General
    Last Post: 2006-07-16, 07:27 PM
