Thread: Problem with open/save dialog box
    2004-08
    Default Problem with open/save dialog box
    I'm having an issue with my laptop where the open and save dialog box opens painfully slow when I'm not connected to the network. It's like it's crashing and showing small pieces of the graphic at a time. It works fine when connected. If I connect remotely through a vpn it's still slow. I'm running ADT 3.3 and have a hp notebook running xp professional with a centrino processor. Thing that gets me is that when I'm in the office everything works great.. and I'm not having any problems with any other programs. Does anyone have and ideas or suggestions?
    2001-10
    Arizona
    2,337
    Default Re: Problem with open/save dialog box
    Clear all of your persistent mapped network drives
    and network places. The slow down when not connected
    is due to it trying to find those drives, that do not exist
    when you are not connected to the work network.
    You may want to setup two profiles on that laptop, one
    for networked another to stand alone.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    2004-08
    Thanks for the advice.. I have a few questions though.. If it were just a network drive issue, wouldn't I see problems from other programs as well? Or perhaps other problems within ADT ? The other thing is that I synchronize with the server every night.. so the network drive that houses my support files, is actually there (work offline)
    13,499
    Hi
    Check out the following Technical Documents on the Autodesk web site under the Knowledge Base section...
    ID: TS45410 - Plot, Page Setup, and Options dialog boxes are slow to display
    ID: TS67762 - Look in list in File Open dialog box is very slow to populate
    ID: TS62597 - Delay before Plot or Page Setup dialog boxes open
    Please note that non of the above directly answer your query, but hopefully they will offer one or two things that you may want to take a look at.
    Have a good one, Mike
  1. No 'Open" or 'Save-as' Dialog Boxes...???
    By kleenhippie in forum AutoCAD General
    Last Post: 2008-09-05, 05:18 PM
  2. Save As... / Open Dialog Box
    By saeborne in forum Revit Architecture - General
    Last Post: 2008-05-21, 04:17 PM
  3. Creating Shortcut in OPEN/SAVE dialog box
    By Dhanjeet in forum Revit Architecture - Tips & Tricks
    Last Post: 2006-03-08, 09:53 PM
  4. Open, Save dialog box missing
    By terencelee3 in forum AutoCAD General
    Last Post: 2006-01-11, 11:15 AM
