Thread: Quickest way to unjoin beam and column and attach column bottom of beam.
    I could stop if I wanted to scowsert's Avatar
    2006-08
    Olympia, WA
    418
    Default Quickest way to unjoin beam and column and attach column bottom of beam.
    Short question
    Whats the quickest way to get from before.jpg to after.jpg (and no not double clicking on the imagine in this post, wiseguy! In Revit.)
    Long drawn out question
    I'd like to change the way the column and a beam intersect.
    Rather then the beam intersecting with the side of the column I'd like the column to be under the beam. When I try to attach the top of the column to the bottom of the beam it says I must unjoin them first.
    The way I've been dealing with this is to go into the column properties and setting the height to some odd ball height below the beam then using attach, top and selecing the beam.
    There must be a better/quicker way. Thoughts?
    2006-06
    Toronto, ON
    2,386
    Default Re: Quickest way to unjoin beam and column and attach column bottom of beam.
    Select the beam, move the blue dots away from the beam, align the edge of the beam with the edge of the column, select the column and use Attach to attach the top of the column to the beam.
    Andre Carvalho
  1. Column connecting to the bottom of a beam - make easier to define it
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2013-01-06, 06:15 PM
  2. Beam to column ???
    By johnthao714 in forum Revit Structure - General
    Last Post: 2010-06-14, 12:10 PM
  3. COLUMN TO BEAM GAP
    By clintonc in forum Revit Structure - General
    Last Post: 2010-06-03, 07:10 PM
  4. attach footing to bottom of linked column
    By Bryan Thatcher in forum Revit Structure - General
    Last Post: 2009-09-23, 01:04 AM
  5. Beam and column attach
    By roland.106412 in forum Revit Structure - General
    Last Post: 2007-02-12, 09:10 AM
