Thread: Create 3d Polyline Step
    28
    Default Create 3d Polyline Step
    Hello- Does anyone know of a Civil 3d routine that can replicate the LDD <Create 3D Polyline Step> command?
    I am trying to create a curb from a breakline collected along the flowline and am open to any other suggestions.
    Thanks-Tom
    2006-12
    Loveland, CO
    734
    Default Re: Create 3d Polyline Step
    I'm not familiar with the step command in LDT but have you tried the stepped offset in C3D? It's the last icon on the feature line toolbar. When you run the command, watch your command line, there are a lot of options.
    Brian J. Hailey PE
    CAD-1
    Civil3D PLUS My blog
    At Your Desk Training
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    1,901
    The Stepped Offset command that Brian refered to is what you are looking for. It is a combination of the LDT Create Curb command and Create Step command. Use the "variable" option to make it behave similar to the Create Step command. These commands only work on feature lines. If you have 3D polylines they will need to be converted.
    Jeff Paulsen
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Also, be aware that the Stepped Offset command was broken in 2008 SP2 - it no longer offsets intermediate elevation points (elevation points that are not at horizontal PIs). This problem is fixed in the 2009 release.
    2006-12
    Loveland, CO
    734
    Quote Originally Posted by sinc View Post
    <sarcasm>Gotta love the new features they and in service packs </sarcasm>
    Brian J. Hailey PE
    CAD-1
  1. 2011: Create a polyline Section from surface?
    By scowsert in forum AutoCAD 3D (2007 and above)
    Last Post: 2011-09-02, 11:03 AM
  2. Create a polyline
    By clintonc in forum Dot Net API
    Last Post: 2010-11-18, 05:27 PM
  3. create alignment from 3d polyline
    By wardorichie in forum AutoCAD Civil 3D - General
    Last Post: 2009-02-22, 02:06 AM
  4. Polyline length set "step"
    By banananjam in forum AutoCAD Map 3D - General
    Last Post: 2008-04-25, 08:35 AM
  5. Step by step guide - create two set-ups
    By VBOYAJI in forum AutoCAD CUI Menus
    Last Post: 2006-03-20, 10:14 PM
