Hi
ADT '07
I've created a DB with mutliple insert points. I have 'grips displayed in blocks' turned on. When I select one of the normal grips (**STRETCH** mode), & because it's a block, it acts like **Move**. This means the DB grips move with it. However if I do the same by selecting one of the DB grips it leaves the other DB ones in there original locations.
So, my question: Is there a way to move the DB grips with the block, or even better make them invisible as they're not really needed once inserted.
Why do the DB grips not move with the block? Seems pointless to me.
Even weirder behaviour is 'Reset Block' which moves the block back to the original grip position instead of the other way around. Why does it do that?
Hope you can help.
I've added an example to hopefully a bit clearer.
