Results 1 to 10 of 10
Thread: Dimension text & arrowheads appear hollow
    2003-10
    2
    Default Dimension text & arrowheads appear hollow
    In AutoCAD 2006 the dimension text and arrowheads appear hollow (no fill) when you hide the viewport or plot using hide. This is a 3d surface model dimensioned in model space. When the viewport is plotted in hide mode the fill of the text font is missing as well as the arrowhead fill and other blocks with polylines also appear hollow. I've tried setting the viewports shadeplot setting as well as textfill with no success. Any other ideas?
    2003-12
    Pittsburgh, PA
    355
    Default Re: Dimension text & arrowheads appear hollow
    Fillmode=1 maybe?
    or Shademode=2dwireframe (I don't if shademode is available in 2006)
    All AUGI, all the time Katika's Avatar
    2004-07
    Perth Australia
    736
    I've just lost the fill in the arrowheads of my model space leaders too, and none of the suggestions fix it. (other than changing the plotstyle of the window so it's not hidden, which defeats the purpose)
    The paperspace leaders fill normally.
    Kathy Taylor
    Senior Structural Draftsperson & Proprietor
    TaylorCAD
    www.taylorcad.com.au
    I don't suffer from insanity - I enjoy it!
    Revit User Phase 3, 4, 5, 4, 3, 5, 4.....
    0,0,0 The Origin
    8,569
    Is your view a true plan view, not oblique?
    Type PLAN.
    John B
    2004-07
    Perth Australia
    736
    Quote Originally Posted by jaberwok View Post
    Type PLAN.
    Yes, at least it was before setting a zoom/annotation scale. Apparently my landing on that dim is behind something too even though there are no objects covering it.....maybe an unused part of an annotation somewhere else?/!
    Not really a problem atm since that job is finished, but might need investigation later if it happens again.
    Kathy Taylor
    TaylorCAD
    All AUGI, all the time jmctamney's Avatar
    Blue Springs, MO
    658
    I see this behavior whenever a drawing is out of plane with the ucs. It usually happens to me after I hold the Shift key and middle button to 3D orbit. Resetting your ucs to world or using "plan" as jaberwok suggested should fix it.
    2004-07
    Perth Australia
    736
    Nope, they're still hollow with wcs when the viewport is set to plot hidden. If I set it to wireframe, I get the fill back.
    Kathy Taylor
    TaylorCAD
    Blue Springs, MO
    658
    Isn't 2D wireframe the setting it's supposed to be on when drawing in 2D? That's my default.
    2015-12
    2,092
    Thats what happens when you "hide" a dimension or text object. You are pretty much SOL doing that all in model space - you either get the dimensions right or hidden solids, not both. Put the dimensions and text in paper space and set the viewport so it plots hidden and you get the best of both.
    If you are going to fly by the seat of your pants, expect friction burns.
    Some say beauty is in the eye of the Beholder... perhaps so, but I've only seen the disintegration beam.
    Everyone else being wrong is not the same thing as being right.
    Certifiable AUGI Addict Robert.Hall's Avatar
    2004-07
    Detroit Michigan
    2,508
    Type PLAN.
    Works like a charm.......I never would have thought to check the view.
  1. Replies: 3
    Last Post: 2007-07-09, 01:52 PM
  2. dimension arrowheads
    By MikeJarosz in forum Revit Architecture - General
    Last Post: 2007-03-26, 05:46 PM
  3. Angular Dimension Arrowheads
    By raddis in forum Revit Architecture - General
    Last Post: 2006-05-31, 03:56 PM
  4. Dimension arrowheads remain visible when Layer is turned OFF
    By joe.giannetto in forum AutoCAD General
    Last Post: 2006-01-06, 05:58 PM
  5. Dimension Arrowheads and Viewport property Hide Plot
    By jhale.77541 in forum AutoCAD Plotting
    Last Post: 2005-08-16, 10:13 PM
