Thread: AutoCAD 2009 help needed with a PIPE ISO drawing
    2007-04
    29
    Default AutoCAD 2009 help needed with a PIPE ISO drawing
    Hey,
    The company I work for does not do much piping (in fact this is the first drawing that is an iso) but I got stuck doing a pipe iso (a simple one) but I don't have anything to go by (an example of a drawing of what I should show).
    Does anyone have an example of a pipe iso that I can go by?
    This is the one I was working on
    2007-04
    29
    Default Re: AutoCAD 2009 help needed with a PIPE ISO drawing
    I'M USING ACAD 2009
    Active Member RICHARD_JONES's Avatar
    2004-06
    DE
    82
    Attached is an iso I worked on recently. It’s strictly a 2d "hand built" iso. You can see in the drawing that I have setup two text styles and two dim styles for creating the dimensions. I also have created a tool button with the following macro ^C^C_dimedit _o used to aline the dimension in the direction I need it to go.
    FYI, I'm working in 2007 I don't know if 2009 has any new tricks for creating iso.s
    Good Luck,
    Rich
    2007-04
    29
    this is what I was looking for thanks a bunch
  1. Copying drawing from AutoCAD 2010 to 2009
    By drdesignz in forum AutoCAD General
    Last Post: 2010-05-20, 07:28 PM
  2. Autocad 2009 driver needed
    By houstonvett in forum AutoCAD General
    Last Post: 2010-01-08, 10:18 AM
  3. Drawing status bar icons in AutoCAD 2009
    By Eddy B in forum AutoCAD Customization
    Last Post: 2009-12-03, 09:22 PM
  4. Restrict AutoCAD 2009 to one drawing per session
    By dave.wright in forum AutoCAD General
    Last Post: 2008-06-25, 01:33 PM
  5. Replies: 8
    Last Post: 2006-11-27, 08:28 PM
