Results 1 to 10 of 13
Thread: Mtext Command in Lisp
    2015-11
    Sydney Australia
    91
    Default Mtext Command in Lisp
    I am trying to write a lisp routine that converts multiple text entities to multiple mtext entities while preserving the insertion point (express tools txt2mtxt wont do this)
    I dont know much about lisp ... but have managed to write something that works for a single entity ...
    Rather than try to change the text to mtext i thought it would be easier to extract all the relevant information from the text entity, erase it and use the command function to create the mtext, however, it crashes after the first entity because i am not able to end the mtext command.
    Any help would be greatly appreciated
    ;;; convert multiple text entities to multiple mtext entities maintaining the insertion point
    ;;; basically create a selection set of the entities to change, extract all the relevant information
    ;;;    ie size, style, rotation angle, insertion point, justification
    ;;; erase the text and create a piece of mtext
    (defun C:Tx2M (/ ss itm elist H V hnd ent ins)
    ;;; convert acad polar angle to a bearing
    ;;; polar angle must be in decimal degrees
    ;;;______________________________________
    (defun polar_ang_to_bng (a)
      (setq a (- 450 a) )
      (if (>= a 360)
             (setq a (- a 360)) (setq a a)
      ) ;if
    	(prompt "\nSelect Text objects to convert to MText: ")
    	(setq ss (ssget (list (cons 0 "TEXT"))))
    	(setq itm 0)
    	(if	ss
    		(repeat	(sslength ss)
    			(setq hnd (ssname ss itm)) ; get the handle for itm
    			(setq ent (entget hnd))		 ;
    			(setq
    		    en_type   (cdr (assoc 0  ent))
    		    en_txt    (cdr (assoc 1  ent))	; the text value
    		    en_lyr    (cdr (assoc 8  ent))	; the layer the text is in
    		    en_size   (cdr (assoc 40 ent))	; text size
    		    en_ang    (cdr (assoc 50 ent))	; text angle
    		    en_style  (cdr (assoc 7  ent))	; text style
    				en_H 			(cdr (assoc 72 ent)) ; get the horizontal alignment of the text
    				en_V			(cdr (assoc 73 ent)) ; get the vertical alignment of the text
    			); setq
    			(if (and (= en_H 0) (= en_V 0))	  ; if the horiz and vert just = 0 then
    			  (setq en_ins (cdr (assoc 10 ent))) ; we have the default insertion point
    			  (setq en_ins (cdr (assoc 11 ent))) ; otherwise get the insertion point
    			(setq en_just "")
    			(cond
    					( (= en_V 3) (setq en_just "T" ) )
    					( (= en_V 2) (setq en_just "M" ) )
    					( (= en_V 1) (setq en_just "B" ) )
    			(cond
    					( (= en_H 0) (setq en_just (strcat en_just "L" )) )
    					( (= en_H 1) (setq en_just (strcat en_just "C" )) )
    					( (= en_H 2) (setq en_just (strcat en_just "R" )) )
    ; angle is POLAR in radians - 0 horizontal increase anticlockwise
    ; convert to degrees & bearings - 0 vertical increase clockwise
    		  	(setq en_ang (/ (* en_ang 180.0) Pi) )
    			(setq en_ang (Polar_ang_to_Bng en_ang)) ; convert polar to bearing
    			(setq en_ang (- en_ang 90.0)) ; subtract 90 because mtext is different
    		  	;(while (> en_ang 180.0) (setq en_ang (- en_ang 180.0)))
    			(command "ERASE" hnd "")
    			(command "Layer" "Set" en_lyr "")
    			(command "MTEXT" en_ins "Height" en_size "Justify" en_just "Rotation" en_ang "Style" en_style "Width" "0" en_txt "")
    		); repeat
    	); if
    ); function
    Greg B
    2003-11
    Dublin, Ireland.
    152
    Default Re: Mtext Command in Lisp
    This seems to work now.
    I don't know how to color the revisions that i made, but I put comments on them.
    (defun C:Tx2M ();;/ ss itm elist H V hnd ent ins)
      (setq a (- 450 a) )
      (if (>= a 360)
      ) ;if
    	(setq itm 0)
    	(if	ss
    ;;;			(setq hnd (ssname ss itm)) ; get the handle for itm
    ;;;			(setq ent (entget hnd))		 ;
    (setq ent (entget (ssname ss itm)))   ;;Get the entity
    (setq EntName (cdr (assoc -1 ent)))  ;;Get the entity name
    			(setq
    			)		; setq
    			(setq en_just "")
    			(cond
    			  		( (= en_V 0) (setq en_just "B" ) )   ;;Check for value = 0
    			(cond
    ;;;			(command "ERASE" hnd "")    ;Take this line out
    			(command "-MTEXT" en_ins "Height" en_size "Justify" en_just "Rotation" en_ang "Style" en_style "Width" "0" en_txt "")
    ;;Use the command line version of Mtext
    		  (entdel EntName)   ;;Delete the old TEXT entity
    		  (setq itm (1+ itm))  ;;Increase the counter
    		); repeat
    	); if
    ); function
    2015-11
    Sydney Australia
    91
    Quote Originally Posted by jmcshane View Post
    Thanks
    ... Did not think of trying the command line version of Mtext, actually did not know there was one, AND incrementing the counter helps a lot also ...
    Thanks again for the help
    GregB
    2015-11
    Sydney Australia
    91
    I still have one problem ... the mtext command seems to be ignoring the text size and uses whatever the current mtext size is
    ie current mtext size =5 size of chosen text entity = 10 ... then the new mtext has a size of 5 not 10
    GregB
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Maybe the text size is specifyed in the Text Style? Height is set to 0 in all my styles and I've never seen that problem.
    Try this multiple text entities to multiple mtext entities routine:
     (defun c:mtxt2mtxt( / *error* ss ss1)
      (defun *error* (msg)
        (if docobj (vla-endundomark docobj))
        (cond
          ((member msg
             '("Function cancelled"
               "quit / exit abort"
               "console break"
          ((princ (strcat " Error: " msg)))
        (princ)
      (prompt "\nSelect Text items to convert to Mtext.")
      (setq ss(ssget '((0 . "Text")))
          count(sslength ss)
        docobj(vlax-get-property (vlax-get-acad-object) "ActiveDocument")
      (vla-startundomark docobj)
      (while (>= count 0)
        (setq ss1(ssname ss count)
              count(- count 1)
        (command "txt2mtxt" ss1 "")
        (princ)
      (princ)
    2015-11
    Sydney Australia
    91
    The Height is set to 0 for the style ....
    I was clutching at straws and eventually changed the position in the command where I set the height
    Originally was ...
    Then changed it to ....
    (command "-MTEXT" en_ins "Justify" en_just "Rotation" en_ang "Style" en_style "Height" en_size "Width" "0" en_txt "")
    and for some unknown reason it now works.
    Thanks for your help ... much simpler coding with error trapping also
    guess i should try and learn visual lisp
    11
    This lip routine works great but it shifts my text location. Is there a way to keep it the same as the original?
    Post Re: Mtext Command in Lisp
    I agree with you about the AutoCAD txt2mtxt function not placing the mtext in the same location as the original text. Here is a version that I wrote to fix that problem. The only thing I couldn't get exactly right was the fit text justification issue. Other than that it matches the layer, color, font style, text height, justification and alignment. Take it for a test ride and see if it's going to work for you.
    Terry
    11
    Perfect! Thanks a ton.
    2008-06
    4
    This routine is great. Thank you for writing it. Just what I was looking for.
  1. Move MText at a certain Z value LISP
    By djin_fre3449006 in forum AutoLISP
    Last Post: 2013-11-28, 08:17 AM
  2. Lisp and Annotative MTEXT
    By bowtle in forum AutoLISP
    Last Post: 2010-02-20, 06:01 PM
  3. Replies: 3
    Last Post: 2009-10-22, 10:19 PM
  4. Mtext in LISP
    By ticad02 in forum AutoLISP
    Last Post: 2009-04-21, 01:59 PM
  5. Replies: 6
    Last Post: 2007-04-23, 01:40 AM
