Thread: CRASH, RECOVER, ANNOTATIVE DIM TEXT SIZE
    2007-08
    76
    Angry CRASH, RECOVER, ANNOTATIVE DIM TEXT SIZE
    when autocad crashes, then i recover the drawing, all of my annotative dimensions text is the size that it should read in paper space. problem is it is reading this big in model space. has anyone had, or solved this problem? i dont know what to do about it, and when it does this on a 6000 sq. ft. residence's dimension plan, its quite frustrating. if i have any dims with center lines they are lost when i change dim styles back and forth to recover what my original dimensions looked like.
    100 Club finney13's Avatar
    2005-03
    Brentwood, TN
    134
    Default Re: CRASH, RECOVER, ANNOTATIVE DIM TEXT SIZE
    What version of CAD are you running? Is this something that has been happening for a while, or is it new?
    2007-08
    76
    2009 now, it happened with 2008 as well.
  1. LISP not grabbing annotative text size properly
    By Jeversole in forum AutoLISP
    Last Post: 2012-05-16, 09:32 PM
  2. Recover Info after Crash
    By mmiles in forum Revit Architecture - General
    Last Post: 2009-06-10, 05:25 PM
  3. Save to recover file on crash
    By payre in forum NavisWorks - Wish List
    Last Post: 2009-03-27, 07:53 PM
  4. 2007 Crash/Recover Issue
    By engymyheart in forum AutoCAD General
    Last Post: 2008-10-31, 06:56 PM
  5. Annotative Text Resets to size 0"
    By mzabritski in forum AutoCAD Annotation
    Last Post: 2007-12-05, 06:03 PM
