Results 1 to 6 of 6
Thread: 64-bit Autodesk Navisworks 2009
    2008-05
    20
    Default 64-bit Autodesk Navisworks 2009
    How can I download or get a trial version of 64-bit Autodesk Navisworks 2009? The Autodesk website has only 32-bit version to download.
    I downloaded it and installed on my 64-bit workstation running on 64-bit XP, it worked the first time but can't find the AutoCAD 2009 plugin, that's mean no .dwg support.
    Then I uninstalled it and reinstalled, it won't let me run the program and I can't use 000-0000000 serial number....
    Please helps!
    I could stop if I wanted to Teresa.Martin's Avatar
    2004-11
    438
    Smile Re: 64-bit Autodesk Navisworks 2009
    Dear Yeun;
    Greetings. Currently there is no 64bit support. You can install Navisworks on a 64bit machine, but you are correct the native dwg/dxf file readers do not work. To get the dwg files into Navisworks, you need to use the NWCOUT command from Autocad.
    Teresa Martin
    Senior Application Specialist, IdeateInc
    Ideate on Youtube! http://www.youtube.com/user/IdeateInc
    Ideate Solutions blogs! http://ideatesolutions.blogspot.com/
    Check out my blog: http://bimnewworld.blogspot.com
    2008-05
    20
    Default Re: 64-bit Autodesk Navisworks 2009
    and would Navisworks Freedom work in 64-bit ?
    2004-11
    438
    Yes it will work in 64bit. Navisworks Freedom only imports NWD or DWF files, so the issue is rather moot for the file readers.
    Best regards,
    Teresa Martin
    2005-12
    20
    Is there a .DWG plug in for this problem yet... or do I still need to nwcout?
    NavisWorks Moderator david.kingham's Avatar
    2004-07
    Fort Collins, CO
    1,329
    No there isn't and they don't have a time slated to get it done (at least that's what they tell us) so I wouldn't expect it till v2010
  1. 64-bit DWG Reader for Autodesk NavisWorks 2009
    By david.kingham in forum NavisWorks - General
    Last Post: 2009-11-03, 02:44 PM
  2. Navisworks Freedom 2009 vs. Autodesk Design Review 2009
    By diesellam in forum NavisWorks - General
    Last Post: 2009-02-18, 06:30 PM
  3. Revit A 2009 IFC files in NavisWorks 2009
    By balsmark in forum NavisWorks - General
    Last Post: 2008-11-30, 01:15 AM
  4. Autodesk Navisworks manage 2009 y autoplant
    By omargarciave in forum Español - Visualización
    Last Post: 2008-05-13, 01:32 PM
