Thread: Legends Transfer between projects
    100 Club D_Driver's Avatar
    2003-11
    Ashland Oregon
    194
    Default Legends Transfer between projects
    It appears that there is a bug in legends being able to copy between projects
    I did a search on legend transfer and there was a lot of bad advice based on how we used to copy schedules from one project to another prior to the Insert From File function (put it on a sheet, copy to anothe sheet in the target project).
    While the following makes intuitive sense (well maybe intuitive for my inner geek): Open up the source legened, copy items to a legend in the target project.
    Unless I am doing something dramatically wrong or it is just a vista 64 bit glitch, here is the rub:
    Lines will copy from one projects legend to another projects legend
    Text will copy from one projects legend to another projects legend
    but a selection set of Text and lines will NOT paste into the target legend.
    Symbols will NOT paste into the target legend
    I went back and tried this on the last version of 2008 with similar results, so it is either my machine/install or a bug.
    I am curious if it is just me, because the threads that advise copy and paste between legends are complete threads from the 9.1-2008 migration cycle and noone seems to mention it....possibly something that broke during one of the 2008 updates? Did a quick scan in the Known Issues thread, nothing popped out at me
    Anyone else?
    It's all fun and games until someone changes the phasing on your schedules... Phasers on STUN Scotti!
    2007-08
    322
    Default Re: Legends Transfer between projects
    I haven't had any problems with copying between legends. You have to have both projects open in the same session, open the original legend, copy what you want, create a new legend in the new project and paste it in. Kind of a pain when you try to lay out sheets and you cant copy legends with them, but it works fairly well. At least in 08. We are migrating to 09 next week after a submittal deadline so I'll have to retest it then.
    Have you tried doing this on another machine?
    Nick
    2003-11
    Ashland Oregon
    194
    Yes, process is good even if a workaround for the reasons you mentioned.
    Does not work on my current machine (traveling, not in office to test on different machines)
    hmmm....edit....
    Today, I can copy/paste multiple items (text and lines [not symbols]) between legends of different projects, yesterday I could not paste (copy seemed fine) if the selection set had both lines and text no matter what I tried.
    same machine, same files....interesting.
    must be the phase of the moon
  1. Transfer filter with another projects
    By swapr78 in forum Revit MEP - General
    Last Post: 2011-04-20, 01:15 PM
  2. What's the best way to transfer Families between projects?
    By mhenderson in forum Revit Architecture - Families
    Last Post: 2010-08-20, 03:44 PM
  3. Transfer Schedule between projects
    By Joshua Kohl in forum Revit Architecture - General
    Last Post: 2010-05-24, 04:58 PM
  4. Transfer Color Fill Legend to other Projects?
    By dgraue in forum Revit Architecture - General
    Last Post: 2008-02-01, 05:52 PM
  5. Transfer Legends?. . .and oh this too.
    By stuntmonkee in forum Revit Architecture - General
    Last Post: 2005-08-16, 07:13 PM
