Thread: limiting the dwg layers
    2005-03
    15
    Default limiting the dwg layers
    Hi ,
    We are just starting to implement revit architecture in our firm. I would like to export the revit model so that my co-worker, who run max 2008, can create the renderings. The problems that we are having is that we have too many layers! Is there a way to simplify the layer structure?
    2003-08
    Vancouver, BC Canada
    3,419
    Default Re: limiting the dwg layers
    Revit maps object categories to layers through File > Import/Export Settings > Export Layers DWG/DXF.
    If you modify this file you can change how many layers are created and what maps to which layer.
    ____________________________
    Dimitri Harvalias LEED AP
    Summit BIM Consulting
    BIMblog.ca
    I was never just a CAD monkey, so I refuse to be a BIMpanzee!
    A BIM without the 'I' is just a BM - those in the medical profession know what that amounts to
    AUGI Addict DaveP's Avatar
    2003-11
    St Paul, MN
    1,370
    If you're on Subscription with both products, you might want to look into the 2009 versions.
    There is now an export to FBX from Revit2009 that can import directly into Max2009 and retain the materials
    Go back to AutoCAD? I'd rather lose my right arm!
  1. Limiting Field Length
    By crystalp in forum AutoCAD Fields
    Last Post: 2010-11-18, 05:29 PM
  2. Revit 2010 Limiting Open views
    By ablaydon in forum Revit Architecture - General
    Last Post: 2010-03-17, 04:37 AM
  3. length limiting IF statement
    By t1.shep in forum Revit Architecture - General
    Last Post: 2009-02-25, 06:16 PM
  4. Limiting the Titleblock Revision Lines?
    By sradley in forum Revit Architecture - General
    Last Post: 2008-11-14, 09:10 PM
  5. Limiting user customization?
    By Joe_cool317 in forum CAD Management - General
    Last Post: 2008-03-28, 06:29 PM
