Thread: shortcut key?
    2004-06
    2
    Question shortcut key?
    When we dimension from the tool palette, the dimension goes on the A-Anno-Dim layer. When we hit the space bar or enter to dimension again, the dimension goes on the current layer. How do we make the dimension from the repeat command using the space bar or enter key automatically go to the correct layer?
    Thanks!
    2001-10
    Arizona
    2,337
    Default Re: shortcut key?
    Sounds like you may need to edit the
    dimension command, and add the same
    script entries to it as exist within the
    dimension command in your palette.
    As the standard behavior of the dimension
    command is to use current layer.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
  1. 2010: shortcut
    By frans.vermonden100021 in forum Dynamic Blocks - Technical
    Last Post: 2012-02-12, 06:57 PM
  2. 2012: Looking for a Shortcut
    By chris4455 in forum AMEP General
    Last Post: 2011-11-17, 11:21 PM
  3. Shortcut Missing?
    By etboards17 in forum Revit - Platform
    Last Post: 2010-03-19, 07:35 PM
  4. Shortcut to z..
    By claus in forum ACA General
    Last Post: 2007-11-28, 10:10 AM
  5. Right Click shortcut
    By jasontirone in forum ACA General
    Last Post: 2004-11-18, 08:56 PM
