Can you create a door tag that goes along the edge of the door? Just numbers and text no box stuff.
see attched
see attched
The standard out of the box template has door tag types without the boxed in surround (they are types)
You can also change the orientation of the tag to vetical or horizontal via the pull-down on the command options line (or by just selecting the tag and hitting the space bar)
Also, you may have some luck loading an annotation tag into the door family. We do that with electrical outlets for instance. You'll have to use shared parameters and I can't remember if the door number parameter is in the door template or not. If not you may have to make a new door number parameter and use that instead of the old one. Anyway, you might be able to pull it off. However, it will show up in ANY plan view you have with that door in it. (AND RCP as well.)
