Thread: RAM->REVIT 2009 protected memory error
    2008-02
    New York
    81
    Default RAM->REVIT 2009 protected memory error
    I'm working on a RAM-Revit 2009 translator in C#.
    After I get a few members in I get the 'attempting to write on protected memory' error message that used to happen in 2008 sometimes.
    I am indeed working with reference values of variables, but it seems to work for the first three beam members ..and then wham!
    Any ideas, could I be doing something wrong?
    2005-12
    Escondido, CA
    89
    Default Re: RAM->REVIT 2009 protected memory error
    Can you pinpoint exactly where you are getting the message? What property are you trying to set? Is it always failing on the same member? Is it possible that the property you are trying to write is set to read-only for one of the members?
    2008-02
    New York
    81
    Hi Elizabeth.
    The error message stopped occuring after a machine restart.
    I haven't encoutered since.
  1. Replies: 4
    Last Post: 2011-09-13, 12:17 PM
  2. Replies: 3
    Last Post: 2009-10-03, 04:21 PM
  3. Attempted to read or write protected memory?
    By c-hawk in forum Revit - API
    Last Post: 2009-08-12, 02:32 PM
  4. Revit Architecture 2009 'Not Enough Memory' Error Message
    By shifali.a in forum Revit Architecture - General
    Last Post: 2009-06-05, 02:12 PM
  5. Out of Memory Revit 2009
    By iankids in forum Revit Architecture - General
    Last Post: 2008-05-15, 12:54 AM
