Thread: INTERNAL ERROR: !dbobji.cpp@6769: eNotOpenForWrite
    2003-06
    38
    Default INTERNAL ERROR: !dbobji.cpp@6769: eNotOpenForWrite
    Thanks goes to all who are up for a challenge,
    I have a AutoCAD file... please bare with me here... originally created in 2008, converted to 2004 and now can not be opened in 2008.
    The acad.err file says:
    INTERNAL ERROR: !dbobji.cpp@6769: eNotOpenForWrite. I have no idea what is causing this. The file was created in 2008 Land Desktop Companion and has point objects called "AECC_POINT"s. Other than that the files are pretty clean.
    Upward and Downward compatibility has never been AutoCAD's strong point, but hopefully there is something I can do to make the process a bit less painful.
    Thanks for the Help, Mike
    Cairo - no, not Illinois
    5,069
    Default Re: INTERNAL ERROR: !dbobji.cpp@6769: eNotOpenForWrite
    can you still open the file in 2004? if so try DXF out and DXF in back to 2k8.
    2003-06
    38
    Yes, the 2004 file is fine in 2004. I have found a work around by wblocking out all MS Data and then piecing the file back together in 2008. I do not understand why this simple process works but it does. The unfortunate problem is this may have to done done over and over until I this project is completed.
    There must be some entity or something that is causing this error!
    2003-06
    38
    Looks like it is a simple fix after all.
    I had locked a few layers... just unlocking the layers is all I have to do!
    completments of Autodesk..
    http://usa.autodesk.com/adsk/servlet...linkID=9240777
    Mike
  1. INTERNAL ERROR: !dbobji.cpp@7319: eNotOpenForWrite
    By eddie9024535672 in forum AutoCAD General
    Last Post: 2013-09-04, 10:30 PM
  2. INTERNAL ERROR: !dobji.cpp@672:eNotOpenForWrite
    By simonaster in forum AutoCAD Civil 3D - General
    Last Post: 2009-08-05, 02:24 PM
  3. INTERNAL ERROR: !dbobji.cpp@6769: eNotOpenForWrite
    By rlehman.124981 in forum Software
    Last Post: 2008-12-17, 02:17 PM
  4. Error when running sub - eNotOpenForWrite
    By bweir in forum Dot Net API
    Last Post: 2006-10-23, 03:54 PM
  5. Crash - !dbobji.cpp@6266:eNotOpenforWrite
    By CADMama in forum AutoCAD General
    Last Post: 2006-07-12, 04:35 AM
